*UPDATE* First Impressions of Release 20160303 and App Compatibility List
(04-08-2016, 01:17 PM)yusijs Wrote: How did you get a proper install? My board is having weird issues; internet connects, but opening a website never completes. Not able to connect a googlr account, which fucks with everything.
(04-09-2016, 04:33 PM)Roverius Wrote: Same board here, 2Gb ram, no Wi-Fi, No Bt
I dont have any Network connection, No Ip-Adress.
PINE is connected to a Gb Switch.
Any Advice how to get LAN connection?
Not sure I had no problems writing the 20160216 img to my microSD card and my network connection seems to be perfectly fine. My pine is connected to my gigabit network and I used the Emby app to stream 1080P mkv's stored on my HTPC and they played fine no buffering or stuttering. I haven't really had a chance to test Kodi out for streaming anything yet because I haven't figured out how to access my movies in Kodi. Not really a Kodi fan, more of an Emby fan.
Could you create an image using Win32DiskImager from your sd card (after unlinking your accounts, of course)? That way we could just write your sd card.
Spotify wants to be in portrait mode on my TV and it's quite ridiculous trying to access the app that way.
Launcher3 and SystemUI constantly crash, tis a shame. I'm not sure why there isn't anything newer, this last OS drop was 2 months ago.
Android image is pretty much unusable at this stage. There's no HDMI CEC and the apps, systemui and launcher3 is always crashing. I wonder how they managed to even give a demo without it crashing...
(04-15-2016, 05:03 PM)xtacocorex Wrote: Spotify wants to be in portrait mode on my TV and it's quite ridiculous trying to access the app that way.
Did you try rebooting or relaunching Spotify? Some of the apps I installed, on first run they start up in portrait then on second run they switch to landscape.
When I tried Spotify the sign-in "page" of the app was in portrait but when I had signed in it went back to landscape.
I allso tried some games earlier today (Prince of Persia Classic and Carmageddon) and they both worked smoothly (as smooth as can be when controlling with a mouse and keyboard).
Personally I'm waiting for the rooted 5.1.1 image to be released (promised this week) so I can hook up my PS4 controllers to the pine and start some serious gaming  Cool Big Grin
Updated my 1st post to reflect the 20160303 Release
Does Android come with the Play Store installed and is there a overscan issue in Android?
Sent from my Nexus 5 using Tapatalk
#19
Yes Play store comes pre installed but you have to update the play services. I'm not noticing an overscan issue although I'm outputing it to a monitor and not a TV.
#20
(04-08-2016, 11:49 AM)g_t_j Wrote:
(04-08-2016, 11:26 AM)gtpboy Wrote:
(04-07-2016, 03:43 PM)g_t_j Wrote: Thank you very much for the feedback you provided about the specific apps!
Personally speaking, you hit a soft spot of mine reporting that TinyCam Monitor runs smoothly as I'm going to use one of my boards as a NVR.
Could you also please check if ''IP Webcam'' is working as well? I know that there is no UVC driver yet so connection to USB cameras in not possible, but I'm curious if the board can execute the specific app. If it does, then I'll just have to wait for UVC capability and I'm done.
Thanks again for the very helpful feedback!
I did install it but have no idea how to use it. I did click on some of the menus and some force closed the app other menus functioned normally I guess. Hope this helps.
Thank you very much for all your help.
I suspect/hope that you got the occasional errors which subsequently forced the app to close due to the absence of the UVC driver. The app can't detect any camera (no USB camera nor the Pine camera module) so it sounds reasonable that the service is forced to close , while navigating in some specific menus.
That was a very helpful post. Please keep it updated with any app you try on your board.
Cheers!
Allwinner engineer currently is porting the UVC driver from their stock library over to Pine A64 Android build, our Android team will get the driver on next week and hopefully will release on first week of May.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 381,845 12-29-2020, 01:13 AM
Last Post: firmwarefile
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 22,791 05-05-2017, 01:50 AM
Last Post: Quezbeme
  is there a good place to learn how to compile a release rxb 0 1,911 02-07-2017, 06:38 PM
Last Post: rxb
  Official Android Release MCZ 0 2,151 12-27-2016, 08:05 AM
Last Post: MCZ
  Can the latest update do not affect the android device gustavowoltmann01 0 1,912 11-15-2016, 09:27 AM
Last Post: gustavowoltmann01
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 23,476 10-29-2016, 04:31 AM
Last Post: joe
  Android 5.1.1 Image Release 20160711 clarkss12 27 33,735 08-27-2016, 08:14 AM
Last Post: neyron
  Build the Lichee and Android source-"Android 5.1.1 Image (HDMI Video Output) Release SuperX 2 4,470 08-12-2016, 02:00 AM
Last Post: xalius
Thumbs Down OTA Update NOT WORKING marco97pa 3 6,295 07-21-2016, 02:25 PM
  App compatibility issues with pine64 Boring 3 4,641 07-06-2016, 02:36 PM
Last Post: Tarjei85
