Python GPIO Library for the Rock64 (R64.GPIO)
#31
I can run under Ubuntu, but can't run the test script under Armbian. Using python3 I get:
root@rock64:/home/sas# python3 gpio_test.py
Testing R64.GPIO Module...
Module Variables:
Name           Value
GPIO.ROCK      ROCK
GPIO.BOARD     BOARD
GPIO.BCM       BCM
GPIO.OUT       out
GPIO.IN        in
GPIO.HIGH      1
GPIO.LOW       0
GPIO.PUD_UP    0
GPIO.PUD_DOWN  1
GPIO.VERSION   0.6.3
GPIO.RPI_INFO  {'RAM': '1024M', 'PROCESSOR': 'BCM2837', 'TYPE': 'Pi 3 Model B', 'REVISION': 'a22082', 'P1_REVISION': 3, 'MANUFACTURER': 'Embest'}
Error: Unable to export GPIO
Error: Unable to set GPIO direction
Testing GPIO Input/Output:
You must setup() the GPIO channel ({0} {1}) first
Traceback (most recent call last):
  File "gpio_test.py", line 42, in <module>
    var_gpio_state = GPIO.input(var_gpio_out)                   # Return state of GPIO
  File "/home/sas/R64/_GPIO.py", line 210, in input
    if validate_direction(channel, 'both') == 0:
  File "/home/sas/R64/_GPIO.py", line 118, in validate_direction
    print("You must setup() the GPIO channel ({0} {1}) first").format(gpio_mode, channel)
AttributeError: 'NoneType' object has no attribute 'format'
Heads up: I'm not dead, and I'm actively working on this library again.
Just updated with bug fixes:
1. Improved GPIO.input compatibility (now returns an int rather than a string).
2. Fixed Python3 compatibility.
3. Updated install instructions in the Github wiki.
I'm working on RockPro64 support now.
(05-06-2019, 11:17 AM)Leapo Wrote: Heads up: I'm not dead, and I'm actively working on this library again.
Appreciate and thanks on working at ROCKPro64 support. Please PM your shipping address (include phone number for shipping purpose), I will send a Rock64 v3 SBC to you.
(11-20-2018, 01:55 PM)pantera Wrote: I can run under Ubuntu, but can't run the test script under Armbian. Using python3 I get:
Module Variables:
Name           Value
GPIO.ROCK      ROCK
GPIO.BOARD     BOARD
GPIO.BCM       BCM
GPIO.OUT       out
GPIO.IN        in
GPIO.HIGH      1
GPIO.LOW       0
GPIO.PUD_UP    0
GPIO.PUD_DOWN  1
GPIO.VERSION   0.6.3
I was getting a similar error when running the test Python file from the terminal using the Armbian_20.08.1_Rock64_bionic_legace_4.4.213_desktop image. I did get it to work using sudo.
To get it to work without sudo I ran the following command from the terminal based on the discussion at https://forum.armbian.com/topic/8714-gpi...-non-root/:
chmod 4775
/usr/bin/python
I don't know secure this is but it worked.
I tried the steps from https://forum.pine64.org/showthread.php?tid=2233 without success.
I'm trying to get a Filament-Sensor working on my rock64 with armbian installed and octoprint. Any help? Gpio Kris saying failed not a pi device.
(03-21-2021, 11:14 PM)Impaled Wrote: I'm trying to get a Filament-Sensor working on my rock64 with armbian installed and octoprint. Any help? Gpio Kris saying failed not a pi device.
Sometimes you can get past this by renaming R64.GPIO to RPi.GPIO.
Internal SoC PullUps are usually between 20K to 100K.
So, using a external PullDown to put it low is like creating a voltage divider with the internal pullup, therefore with a external 20K, you get a voltage that is neither a LOW or a HIGH, explaining why you get interrupts triggered repeatedly.
If you use a external 1K as a pulldown instead, you will see that will be close to 0V ...
__________________________
First Motion Products
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 219 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,181 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,604 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,034 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 315 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,849 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,476 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,053 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 738 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 939 10-07-2022, 07:50 PM
Last Post: rookie_267
