slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#71
Thank you guys, now I can access my Rock64.
Any chance that I can establish a compile environment on Slackware to build some service that I need?
(04-10-2020, 02:04 PM)Enig123 Wrote: Thank you guys, now I can access my Rock64.
No problem.
all necessary packages are in category D http://dl.fail.pp.ua/slackware/slarm64-c...slarm64/d/
use the package manager installpkg or slackpkg
update:
slarm64-current-aarch64-base-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz
slarm64-current-aarch64-base-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz
slarm64-current-aarch64-xfce-rootfs-20200118-4.4.222-rock64-build-20200509.img.xz.md5
kernel 5.6.10
slarm64-current-aarch64-base-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz
slarm64-current-aarch64-base-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz
slarm64-current-aarch64-xfce-rootfs-20200118-5.6.10-rock64-build-20200510.img.xz.md5
kernel 5.7.15
slarm64-current-aarch64-base-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst
slarm64-current-aarch64-base-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst
slarm64-current-aarch64-xfce-rootfs-20200628-5.7.15-rock64-build-20200813.img.zst.md5
donation   slarm64
(08-13-2020, 01:16 PM)mara Wrote: kernel 5.7.15
can someone confirm the operability of this image, on his board version 2.0 is loaded and there is an output to HDMI, but there are also unsuccessful attempts to run on 3 boards version 2.0
thanks.
update
the problem of outputting to the monitor was found out when using the converter HDMI-to-VGA on the 5.7 kernel
donation   slarm64
kernel 5.8.3
slarm64-current-aarch64-base-rootfs-20200628-5.8.3-rock64-build-20200824.img.zst
slarm64-current-aarch64-base-rootfs-20200628-5.8.3-rock64-build-20200824.img.zst.md5
donation   slarm64
(08-20-2020, 09:48 AM)mara Wrote: can someone confirm the operability of this image, on his board version 2.0 is loaded and there is an output to HDMI, but there are also unsuccessful attempts to run on 3 boards version 2.0
thanks.
For different batch of Rock64 board version 2.0, the software/OS support can be quite different.
As I know, older version 2.0 has serious Ethernet issue with OpenBSD, while more recent batch is well supported. Hope this info helps.
thanks.
Thanks, both the old and the new kernel work on version 2.0 of my board (it's a pity there is no way to check for 3.0), in the old 4.4.y kernel video plays well up to 4K.
donation   slarm64
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,362 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 335 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 610 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,389 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,413 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 934 08-29-2022, 01:22 PM
Last Post: ramprasad
