slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#41
The following links appear to be broken in this forum and on the wiki site.
site: fail.pp.ua
downloads: http://dl.fail.pp.ua/slackware/images/rock64/
development: https://bitbucket.org/sndwvs/slackwarearm
Is there a special incantation necessary to access these sites?
(07-31-2018, 04:10 PM)1of7 Wrote: The following links appear to be broken in this forum and on the wiki site.
        site: fail.pp.ua
Already inform Slackware in-charge person, waiting for their reply.
Thank you
update kernel 4.4.153
create a basic installation image:
slack-current-aarch64-miniroot_18Aug18-4.4.153-rock64-build-20180901.img.tar.xz
slack-current-aarch64-miniroot_18Aug18-4.4.153-rock64-build-20180901.img.tar.xz.md5
Update Slackware Aarch64 Miniroot (ROCK64) 20180901 on Wiki and PINE64 Installer.
update kernel 4.4.162
slack-current-aarch64-miniroot_29Sep18-4.4.162-rock64-build-20181028.img.tar.xz
slack-current-aarch64-miniroot_29Sep18-4.4.162-rock64-build-20181028.img.tar.xz.md5
eMMC -> /dev/mmcblk0p1
README.TXT
slack-current-aarch64-miniroot_29Sep18-4.4.162-rock64-build-20181101.img.tar.xz
slack-current-aarch64-miniroot_29Sep18-4.4.162-rock64-build-20181101.img.tar.xz.md5
xfce image:
slack-current-aarch64-xfce_29Sep18-4.4.162-rock64-build-20181101.img.tar.xz
slack-current-aarch64-xfce_29Sep18-4.4.162-rock64-build-20181101.img.tar.xz.md5
Multimedia
The video is played by the MPV player, which is configured with the default profile x11 (for playing divx/xvid)
and the profile rkmpp (for playing h264/h265/VP9 720p,1080p)
example:
mpv --profile=rkmpp videofile.{mkv,mp4}
Updated Slackware Aarch64 Miniroot (ROCK64) 20181101 on Wiki and PINE64 Installer.
Updated Slackware Aarch64 XFCE (ROCK64) 20181101 on Wiki and PINE64 Installer.
Thanks for the images. I need to compile a driver for a usb-ethernet adapter, but can't seem to find the make utility. Is it installed? Now I am using the xfce installation. Previously I tried the miniroot, but it seems it does not have any development tools. At least I could not find gcc. THanks
(11-18-2018, 12:09 AM)KarlF Wrote: Thanks for the images. I need to compile a driver for a usb-ethernet adapter, but can't seem to find the make utility. Is it installed? Now I am using the xfce installation. Previously I tried the miniroot, but it seems it does not have any development tools. At least I could not find gcc. THanks
download slackpkg-2.83.0-noarch-4.txz
wget http://dl.fail.pp.ua/slackware/slarm64-current/slarm64/ap/slackpkg-2.83.0-noarch-4.txz
installpkg slackpkg-2.83.0-noarch-4.txz
use slackpkg package manager
slackpkg update
slackpkg install d
where d means all packages from the development section
you will probably also need the l section of the library
https://docs.slackware.com/slackware:package_management
update:
    - glibc 2.29
    - kernel 4.4.172
    - video hardware decoding via mpv
      configured by default to output video via x11 (divx/xvid)
      using profile --profile=rkmpp play video MPEG-1, MPEG-2, MPEG-4, H.263, H.264, H.265, VC-1, VP9, VP8, MVC
slack-current-aarch64-miniroot_01Feb19-4.4.172-rock64-build-20190202.img.xz
slack-current-aarch64-miniroot_01Feb19-4.4.172-rock64-build-20190202.img.xz.md5
slack-current-aarch64-xfce_01Feb19-4.4.172-rock64-build-20190202.img.xz
slack-current-aarch64-xfce_01Feb19-4.4.172-rock64-build-20190202.img.xz.md5
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 139 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,347 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 331 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 605 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 603 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,336 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 586 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 643 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,250 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 929 08-29-2022, 01:22 PM
Last Post: ramprasad
