slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
(04-12-2018, 09:35 PM)mara Wrote: good afternoon,
tell me:
  1.  what kind of image was used
  2. on which the image of a sdcard or emmc was recorded
  3. when downloading this board is installed emmc
1. unzip and then write to sdcard or emmc by PINE64 installer
      slack-current-aarch64-miniroot_06Mar18-4.4.115-rock64-build-20180311.img.7z
      slack-current-aarch64-xfce_06Mar18-4.4.115-rock64-build-20180311.img.7z
2. xfce ver. tested on emmc only and miniroot ver. tested on sdcard only
3. I use PINE64 installer. so....
I just tried on a Sony 1080p tv and got the same error message.
Is it ok to write your image to sdcard by Etcher(PINE64 installer)?
Thank you for your reply
this is not a mistake, the system is waiting for more.
after writing in the emmc image, you must mount /dev/mmcblk1p1
and make changes
add to the file /media/boot/uEnv.txt
     parameter rootdev=/dev/mmcblk1p1
     and fix it in the /media/etc/fstab file mmcblk0p1 on mmcblk1p1
after that, reboot before removing the sdcard
summing up what needs to be done:
mount /dev/mmcblk1p1 /media
echo "rootdev=/dev/mmcblk1p1" >> /media/boot/uEnv.txt
sed -i 's:mmcblk0p1:mmcblk1p1:' /media/etc/fstab
hello, I tried slack-current-aarch64-xfce_06Mar18-4.4.115-rock64-build-20180311.img.7 with only sdcard / emmc not have / by Etcher (PINE64 installer).
but it does not start.
how to run slack-current-aarch64-xfce_06Mar18-4.4.115-rock64-build-20180311.img. from sdcard? please help .
in this image you need to change the root disk
mount your sdcard
in the file /boot/uEnv.txt remove the line rootdev=/dev/mmcblk1p1
and also change the file /etc/fstab mmcblk1p1 on mmcblk0p1
update images:
slack-current-aarch64-miniroot_14Apr18-4.4.126-rock64-build-20180414.img.tar.xz
slack-current-aarch64-xfce_14Apr18-4.4.126-rock64-build-20180414.img.tar.xz
(04-14-2018, 12:04 PM)mara Wrote: update images:
ok. I tried to solve the problem in many ways but without a result. still does not boot from sd card. the same with these new images from the link you have set up. I leave this project for some time, maybe it will come back to it someday.
thanks for the help
Unzip and write to SDcard or eMMC by PINE64 installer
eMMC  - slack-current-aarch64-miniroot_14Apr18-4.4.126-rock64-build-20180414.img
SDcard - slack-current-aarch64-xfce_14Apr18-4.4.126-rock64-build-20180414.img
1. Tested on Rock64 4GB board
Power up Rock64 with eMMC and SDcard. It auto running until certain stage it show rebooting in 10sec message.
After reboot, the monitor unable get any display.
If reboot the board again get Fatal error or running until certain stage show rebooting in 10 sec
Please advice how to get the OS work on Rock64 4G board.
2. Tested on Rock64 2GB board
Power up Rock64 with eMMC and SDcard. It will auto running until show Login page.
What is login and password ?
note : both board have internet connection.
Please advice.
Thank you.
hi pineadmin,
all images are designed for sdcard,
if you write them on emmc you need to do the following manipulations:
      add to the file /boot/uEnv.txt
      and fix it in the /etc/fstab file mmcblk0p1 on mmcblk1p1
Quote:What is login and password ?
login: root
password: password
Hello could you host a torrent?
Your webserver is incredibly slow (and spotty) to download from. I'll happily assist in seeding.
(04-28-2018, 05:03 PM)valarauca Wrote: Hello could you host a torrent?
ok, http://dl.fail.pp.ua/slackware/images/ro...cy.torrent
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 150 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,353 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 334 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 613 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 608 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,359 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 591 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 650 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,313 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 929 08-29-2022, 01:22 PM
Last Post: ramprasad
