slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
Somehow changing mac address by adding in /etc/rc.d/rc.inet1.conf 'HWADDR[0]="xxx"' didn't work anymore.
I am quite sure it used to work correctly.
Edit: Another quick question is, how am I supposed to do to clear temp files that have been downloaded during upgrading?
Hi mara,
I have tried with the latest image with kernel 5.11.11 this weekend, but it seemed not stable enough for long time running yet.
The most stable version is still 4.4.x kernel, I would hope you guys can keep updating the old but most stable kernel. I understand that the development has been mostly shifted to newer kernel, please just don't abandon the old kernel before the new ones getting more stable.
(04-26-2021, 07:58 PM)Enig123 Wrote: Hi mara,
Hi Enig123,
migration from 4.4.y will most likely be 4.19.y supported by rockchip.
donation   slarm64
kernel 5.12.0
slarm64-current-aarch64-base-rock64-5.12.0-build-20210502.img.zst
slarm64-current-aarch64-base-rock64-5.12.0-build-20210502.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.12.0-build-20210502.img.zst
slarm64-current-aarch64-xfce-rock64-5.12.0-build-20210502.img.zst.sha256
donation   slarm64
update kernel 5.13.6
slarm64-current-aarch64-server-rock64-5.13.6-build-20210731.img.zst
slarm64-current-aarch64-server-rock64-5.13.6-build-20210731.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.13.6-build-20210731.img.zst
slarm64-current-aarch64-xfce-rock64-5.13.6-build-20210731.img.zst.sha256
donation   slarm64
Big Grin
I really like your project, and need it.
But how do I verify the downloaded files, the main site doesn't use https, can you provide a *.asc key verification for each file?
Or is there another way to verification the files now?
(08-14-2021, 12:17 PM)erzjbuao Wrote: I really like your project, and need it.
yes, when installing using slackpkg, the GPG validation option is enabled by default.
slackpkg update gpg && slackpkg update
donation   slarm64
update kernel 5.14.1
slarm64-current-aarch64-server-rock64-5.14.1-build-20210907.img.zst
slarm64-current-aarch64-server-rock64-5.14.1-build-20210907.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.14.1-build-20210907.img.zst
slarm64-current-aarch64-xfce-rock64-5.14.1-build-20210907.img.zst.sha256
donation   slarm64
update kernel 5.15.3
slarm64-current-aarch64-server-rock64-5.15.3-build-20211120.img.zst
slarm64-current-aarch64-server-rock64-5.15.3-build-20211120.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.15.3-build-20211120.img.zst
slarm64-current-aarch64-xfce-rock64-5.15.3-build-20211120.img.zst.sha256
donation   slarm64
Installation README.TXT
update kernel 5.16.2
slarm64-current-aarch64-server-rock64-5.16.2-build-20220125.img.zst
slarm64-current-aarch64-server-rock64-5.16.2-build-20220125.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.16.2-build-20220125.img.zst
slarm64-current-aarch64-xfce-rock64-5.16.2-build-20220125.img.zst.sha256
donation   slarm64
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 136 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,330 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 324 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 596 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 597 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,264 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 583 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 636 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 32,976 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 918 08-29-2022, 01:22 PM
Last Post: ramprasad
