Configuring the PCIe x4 slot to act as 4 individual x1 ports
I'm interested in connecting more than a single PCIe device to the RockPro64.
I know that it woud be possible to use a card which includes a PCIe switch chip to connect multiple PCI Express devices to the RockPro64, but that would be expensive (as well as adding latency and power usage), so I wondered if there was a simpler solution, using a simple breakout card (or custom add-in card), along with a suitable firmware config e.g. device tree overlay, to reconfigure the PCIe x4 slot as four logical PCIe x1 ports?
A custom PCIe card (or breakout card) could then be used to connect multiple PCIe x1 devices to the slot.  The application I had in mind was connecting four Asmedia ASM1061 SATA AHCI host adaptors to give 8 SATA ports for a NAS setup.
I know that various Intel chipsets support this sort of flexible PCIe configuration, but didn't know if the RK3399 did?  Any ideas?
Thanks,
Tim.
The RK3399 root complex does not support splitting up the port into individual links, so you need a riser card with a PCIe switch...
But with such a switch card, the RockPro64 could become an amazingly cheap crypto mining host, as long as drivers are available.
(04-02-2018, 09:32 AM)fonix232 Wrote: But with such a switch card, the RockPro64 could become an amazingly cheap crypto mining host, as long as drivers are available.
But the GPU card for mining is very expensive !!!
Yes it is. But before the RockPro64, people would spend 250-300$ on a motherboard that can host 4-8 cards even with splitters or switches. With the RockPro64, they can cut the prices down a bit.
You can take any ITX m/b with 25W x64 CPU and PCI-e slot (@x4)
SoC are for embedded purposes (gpio and some storage/network), not for mining rig-s Smile
(03-07-2018, 08:39 AM)TimSmall Wrote: The application I had in mind was connecting four Asmedia ASM1061 SATA AHCI host adaptors to give 8 SATA ports for a NAS setup.
Why not just connect one dual-port SAS card? That will support 8 SATA drives, no problem (a single SAS port can be broken-out into 4 SATA ports with a simple adapter cable)
You are outdated. Wink
8 x RX 580 + 1800 Watt PSU ready to rock and roll : https://pt.aliexpress.com/store/product/...Title=true
OR
8 x RX 570 + 1800 Watt PSU ready to rock and roll : https://pt.aliexpress.com/store/product/...Title=true
When I search on AliExpress for "pci-e x1 pci-e x16 mining", I think that I see what you want.
You just need a controller with PMP support and an enclosure like the Mediasonic 8x USB3/eSATA. I am using two successfully with ZFS for many years with 16 drives over two eSATA cables or even a single USB3 with a hub in a pinch.
  Compatible PCIe Sata Controller spacebricker 1 1,555 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,670 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 1,319 11-28-2022, 05:12 PM
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,473 11-27-2021, 11:38 PM
Last Post: Cerberus
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 4,968 02-17-2021, 11:35 AM
Last Post: dml-pc
  Nvidia GPU on PCIe User 18962 4 4,840 12-22-2020, 02:54 PM
Last Post: amiraeva
  Won't boot with 2.5GBe PCIe adaptor connected voltagex 1 2,898 10-20-2020, 12:22 PM
Last Post: xmixahlx
  PCI-E Express card with SIM card slot for rockpro running android 8 seaurchin 3 4,703 07-21-2020, 07:58 AM
Last Post: pgwipeout
  RockPro64 pcie Gpu Davidos 8 15,188 07-14-2020, 05:11 PM
Last Post: ProDigit
  PCIe failure odhinnhrafn 11 12,267 03-16-2020, 08:39 AM
Last Post: odhinnhrafn
