Upgrading to pre-release failure
I just upgraded from 0.6.15 to 0.6.22 of xenial minimal install. Now i can't ssh to it.  When I edit the sources file and ran a apt-get update and apt-get upgrade it said 2 had been held back, which were the new pre-release sources. So I ran an apt-get install instead which seemed to work, but when i did a restart, i can't access it but can ping the IP.  Can anyone give some help...
I also have found it impossible with my near limited linux experience to set a static ip address using standard tips from ubuntu forums.  Not sure where i'm going wrong...
EDIT
Sorry, my bad, it had changed IP address on me. Now working fine. Not sure why the sudo apt-get upgrade didn't work though.
(02-25-2018, 10:57 PM)thewonderer Wrote: RE: Upgrading to pre-release failure
EDIT
What tutorials did you use to set a static IP address and from which forums? I'd also like to find the exact steps how to edit the sources file.
All depends on which Linux build you choose, whether you'll use the CLI or GUI.
EDIT: I ended up using my router to reserve the IP address rather than using static as I found that the static ip address wouldn't stick after a restart.
  Armbian 22.02 Release Announcement TRS-80 0 1,011 02-28-2022, 05:06 PM
Last Post: TRS-80
  RETRO-GAMING: UPDATED RELEASE OF RECALBOX FOR THE ROCK64 Mrfixit2001 32 51,274 05-22-2021, 07:01 AM
Last Post: fartadeadrian
  Armbian 5.4.43: Network is unreachable; Red LED blinking; RNG failure? aves 1 2,921 07-27-2020, 02:04 PM
Last Post: aves
  Release 0.9.14 Ubuntu Mate desktop, LXDE, OMV, Docker CE (container) Luke 1 4,068 09-19-2019, 07:00 AM
Last Post: Malmgren
  Upgrading Debian Stretch image to Buster cosuhi 2 4,717 08-27-2019, 02:42 AM
Last Post: Malmgren
Star [archived] New Stable release from Ayufan (0.8.3) Luke 3 6,864 07-10-2019, 10:40 AM
Last Post: Malmgren
  ayufan 0.7.12 pre-release images (help testing) Luke 1 4,574 03-22-2019, 05:11 PM
Last Post: Luke
Star 0.7.8 Linux release from ayufan for Rock64 Luke 30 64,753 02-25-2019, 02:53 PM
Last Post: Luke
Big Grin ANNOUNCING *BETA* RELEASE OF RECALBOX FOR THE ROCK64 Mrfixit2001 70 108,481 01-31-2019, 03:53 PM
Last Post: Luke
Smile [Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE Mrfixit2001 95 90,743 08-04-2018, 01:47 AM
Last Post: Luke
