Power Via usb
Hi another question I want to be able to power my rock64 by usb so I can plug direct into USB power supply. Will this adapter from store work or is there more to it? Also will 5v 2.4a be sufficient enough to power the rock64? Thanks.
https://www.pine64.org/?product=2-meters...ower-cable
Officially the R64 requires 3A 5V, but I've managed to power it on with less than that. The question is what load will it be under and what peripherals will be connected.
Ok great. I just use rock64 as media player usually only have usb connected that I play movies off however I am going to add dac which may affect things somewhat?
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 329 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,215 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 4,637 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  Alternative power supply ju0n 0 1,022 09-06-2022, 02:46 AM
Last Post: ju0n
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 4,436 01-02-2020, 02:26 PM
Last Post: dpgraham
  Using a stronger power supply myn4m3 1 2,868 06-23-2019, 05:01 PM
Last Post: Rocklobster
  USB3 enough to power 2,5 external HDD? va88 11 14,180 06-06-2019, 03:40 PM
Last Post: va88
  How to check if my power supply is underperforming? va88 3 4,557 06-02-2019, 05:59 PM
Last Post: va88
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 5,904 01-09-2019, 01:02 AM
Last Post: t4_4t
  Boot on power-up vicencb 1 2,911 11-26-2018, 11:45 PM
Last Post: evilbunny
