Rock64 GPIO
Question
Hi There,
I have just received my Rock64 4GB board Smile . I plan to use this as a OMV dedicated machine. Since this board will run headless using Ayufan's stable release of the OMV image which I plan to install on the 16GB eMMC module, I would like to have a 16x4 lcd screen to monitor basic status of the board.
Would anyone know if the GPIO is enabled by default or would I need to install the RPi.GPIO python module?
Any help or advise from the community would be greatly appreciated.
anyone has input on this? RPi.GPIO python module for Rock64?
i have not read any posts of a port being completed and available for download. there was a port for pine64 but not sure how much help for a rock64 port that would be. as far as gpio being available i'd say yes but that is a different issue than a gpio module.
I stuck with change orange pi to rock64 to migrate the nettempsoftware (something like domoticz)
I'm also waiting/looking wiringpi for rock64.
regards
I'm writing a clone of RPi.GPIO for the Rock64, which you can find here: https://forum.pine64.org/showthread.php?tid=5902
All of the basics are already implemented and working. Handling LEDs, buttons, PWM, etc. is already quite do-able.
thx
I found it after wrote the post
  Are HW design files available for ROCK64? irenek 3 4,528 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 278 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 974 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 576 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,040 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,646 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,408 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,498 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,168 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,826 09-28-2021, 03:07 PM
Last Post: TRS-80
