Rock64 dac
Hi what OS is dac from store compatible with? Can it work with android, LibreELEC etc or will I have to use volumio? Thanks.
(02-23-2018, 11:14 AM)Nelly Wrote: Hi what OS is dac from store compatible with? Can it work with android, LibreELEC etc or will I have to use volumio? Thanks.
I know that it works with: stock android, ATV, LibreELEC and Volumio out of the box. I am pretty sure that getting it to work with other OS' is probably not too difficult.
Thank you for this. Is there anything special I need to do to get working on android or will it detect and start playing audio through dac automatically?
  Are HW design files available for ROCK64? irenek 3 4,705 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 318 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,042 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 612 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,165 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,714 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,477 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,579 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,444 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,966 09-28-2021, 03:07 PM
Last Post: TRS-80
