boot option document confusion
I managed to get a decent printout of the boot option document, but what I read is very confusing.
In booting from an sd card, a list of addresses and what goes where seems quite grossly at odds when totalled with a simple calculator.
For instance, the kernel image (I am assuming is vmlinux,) which in the version v4.14I.15-rt13 I just built, is 147871544 bytes, or 0x8D05738, and would extend quite some megabytes past the location that begins the file system image.
Do I have the wrong document, or what do I not understand?
Gene83
Which document are you referring to?
The link is:
<http://opensource.rock-chips.com/wiki_Boot_option>
which describes how to build a bootable SD/TF card, Seems there are 4 main ways to boot these things so I'm trying to follow the scenario as shown under the "Boot from SD/TF Card" Reduced to keep the gfx from overflowing, it is at about the end of page 5 of 7 so its some scroll down from the top of this link to get there..
Thanks xalius, gene83
You don't have to put your initrd/kernel/dtb directly on the image, u-boot can load those from a partition like /boot or directly from your rootfs.
Have you looked at how ayufan builds the linux images?
https://github.com/ayufan-rock64/linux-build
No, I've not seen that xalius, but thanks for the link, I grabbed the zip and will study that carefully.
Thanks, gene83
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 626 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,785 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,051 06-27-2022, 06:52 PM
Star New Retro-Gaming Option: R-CADE Mrfixit2001 0 2,448 12-07-2021, 10:35 AM
Last Post: Mrfixit2001
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,577 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,108 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,865 05-19-2020, 06:43 PM
Last Post: Rocklobster
  Rock64s will not boot any OS camosoul 2 3,436 05-19-2020, 06:38 PM
