Cannot control volume with amixer command
Hi everyone,
I am using Rock64 and trying to play mp3 files on headphone jack. The playback part is working fine. I having trouble with controlling the volume with amixer command. When I try amixer sset Master 100 it shows me error "Cannot find simple control 'Master',0"
The reason behind the use of amixer is I have ported this application from raspberry pi and I need to keep it consistent on either device. I am using Debian stretch minimal image.
Exact version:
Linux rock64 4.4.77-rockchip-ayufan-136 #1 SMP Thu Oct 12 09:14:48 UTC 2017 aarch64 GNU/Linux
Also, amixer scontrols command does not return anything.
Kindly help.
Thanks!
(02-12-2018, 12:22 PM)user_rock Wrote: Also, amixer scontrols command does not return anything.
Mth kindly gave me amixer settings to control the master volume.
Thanks a lot! Please mention the actual linux file name to copy these settings into..
(02-19-2018, 04:08 PM)user_rock Wrote: Thanks a lot! Please mention the actual linux file name to copy these settings into..
try putting it in /etc/asound.conf
  Motion control tera1973 0 1,625 06-12-2018, 05:27 AM
Last Post: tera1973
  Astroimaging Control mcgillca 2 3,530 11-01-2017, 03:49 AM
Last Post: mcgillca
