ROCK64 STEREO AUDIO DAC ADD-ON BOARD
Which pins does the DAC board use? It looks like it uses the 20 pin. Does this mean that it leaves the 40 pin GPIO pins free to use?
(02-06-2018, 10:01 AM)angelscream09 Wrote: Which pins does the DAC board use? It looks like it uses the 20 pin. Does this mean that it leaves the 40 pin GPIO pins free to use?
yes, the 40 pin GPIO pins are free to use. For more Pi2 and Pi5+ bus, DAC board schematic, you can refer to PINE64 wiki page: http://wiki.pine64.org/index.php/ROCK64_...ifications
I'm struggling to find which pins is connects to ... Could someone post a pic with the dac mounted?
Thanks in advance!
What image is better for use with the DAC? Will it work only with Volumo or other images will work too?
bin4ry, have you succeeded?
The DAC runs not synchronous to the I2s clock form the SoC/Rock64.
Which means DAC's have to drop and/or duplicate audio samples.
So do not expect quality sound, regardless which distro used.
See Thread "I2S1_MCLK".
@moris, see jumper J3, http://files.pine64.org/doc/rock64/ROCK6..._Board.pdf
Isn't that what you want?
(11-17-2018, 09:15 AM)antonv Wrote: @moris, see jumper J3, http://files.pine64.org/doc/rock64/ROCK6..._Board.pdf
J3 1-3 => asynchronous to SoC.
J3 2-3 useless so far as no MCLK on Pin 3.
Wow, indeed, I only have sound in one position of the J3 jumper, and silence in the other position (they are not labeled, but I guess the working one is 1-3).
According to the schema, MCLK should be there...
Maybe we do something wrong? Or some workaround?
  Are HW design files available for ROCK64? irenek 3 4,528 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 278 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 974 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 576 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,040 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,647 11-07-2022, 05:45 PM
Last Post: olivercfc
  Audio Pot Board Questions vfr400racer 4 2,961 10-11-2022, 09:21 PM
Last Post: Roberto2020
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,408 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,498 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,169 03-04-2022, 06:56 AM
Last Post: killor
