HLS streaming is stuttering on Android
If you play a HLS stream in Chrome Browser or VLC player it stutters every 1-2 seconds.
Doesn't play well at all.
Any solution for this?
i was unaware the hls worked very well on any client , except for perhaps on an android chrome plugin (maybe) that was not on an apple o/s. what combinations of o/s & hardware have you used to successfully play hls that are not apple o/s related?
as far as vlc most of the time it takes some experimentation with the bitstream selection based what your isp bandwidth is. and it's best to start with a medium bitstream and work up or down as needed.
I played HLS video on RK3229 Nougat, a processor also from Rockchip that is even slower than RK3328 and in Chrome browser and VLC Media app, HLS streams play perfect without any stuttering.
So the problem must be with outdated Android software used on Rock64.
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,266 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,027 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,554 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,530 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,018 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,502 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,015 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,577 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,725 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,793 09-09-2020, 08:44 AM
Last Post: BowerR64
