Debian Plex Installation Package
In case that someone wants to install Plex in Debian, you can download the last version from https://forums.plex.tv/discussion/221444...-odroid/p1
I am using ayufan Debian Stretch.
The steps are enable armhf and install the package with sudo dpkg -i filename.deb
(01-05-2018, 06:46 PM)dejikocv Wrote: In case that someone wants to install Plex in Debian, you can download the last version from https://forums.plex.tv/discussion/221444...-odroid/p1
I may have to give this a try. I'm not having good luck running Kodi smoothly for my local videos (especially HVEC). Are you able to play said videos this way through this particular OS? I want to be able to use a web browser as well as other things (which is why I don't want to go the OpenElec way).
EDIT: Never mind. That link you provided is only for beta members or something. It won't let me view anything on that forum, even after becoming a new member.
If you are interested in NAS/media streaming, maybe you should try OMV armhf distribution?
Easy web-based setup, most, even very messed up CFG accessible via web based config, SMB, NFS, PLEX and some other plugins supported and configured "out fo fthe box" via OMV web admin, rest to be installed at will.
Ayufan recommends this distro for NAS/SMB.
Best local network speeds so far for me.
  How to update/compile Debian 12.5? Wizardknight 3 435 03-29-2024, 05:01 AM
Last Post: gedas07
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,389 10-12-2023, 05:14 PM
Last Post: tpaul
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 5,278 08-12-2021, 04:55 AM
Last Post: igorp
  Debian build from mrfixit2001 Luke 18 27,272 05-17-2021, 02:35 AM
Last Post: Wizzard
  Debian kernel stuck at 4.4.167 Enig123 5 5,647 12-29-2020, 12:57 PM
Last Post: kwinz
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 5,274 09-21-2020, 04:33 AM
Last Post: as365n4
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,314 08-31-2020, 01:41 AM
Last Post: as365n4
  pcsx rearmed on rock64 debian stretch does not go fullscreen RockyBoulder 2 4,235 05-09-2020, 03:15 AM
Last Post: lawrencejd
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,165 01-20-2020, 12:25 PM
Last Post: kf5zmi
  Headless installation of Real VNC server on Rock64 possible? hg6806 3 5,261 11-18-2019, 04:32 AM
Last Post: evilbunny
