keyboard
I'm working many hours on terminal.
I need normal keyboard on pinebook. normal PgUp/Down, Home,End without any switch of function keys.
I need altgr for my Polish language chars
all functions keys (and esc for vi ;-) )
or meybe some other f13-f16 some for japanese chars " ' o
I need in new version scroller or torus analog switc for volume control. no only keys for example alt+30 decress right = 30% volume increase.
ctr+30 degres change brightes. etc.
If i would like to play with tempes ;-) i can use it.
Keyboard and terminal mode is very important for programers, tex or other normal users. I learn unices from 30 yeasrs. Please give me back my normal keyboard.
if you got a couple hours to try out something it may help you. put an android image on pinebook then install hacker keyboard and termux terminal. then there is also a script to install archlinux inside termux.
https://github.com/sdrausty/termux-archlinux
(01-04-2018, 07:53 PM)dkryder Wrote: if you got a couple hours to try out something it may help you. put an android image on pinebook then install hacker keyboard and termux terminal. then there is also a script to install archlinux inside termux.
phisicaly keyboard is better, one device is better than 2 or 3 and wires (keyboard, wired, screen)
pinebook is good because this is all in one. But keyboard is not for hacker, programmer other than english language users
(01-16-2018, 03:02 PM)letarg Wrote: phisicaly keyboard is better, one device is better than 2 or 3 and wires (keyboard, wired, screen)
I use the Pinebook for translating KDE desktop to Slovak, which is a language that use also the special characters and do not have a problem Smile
  Did pine64 change the keyboard? Hsingai 1 3,843 08-10-2020, 06:52 PM
  different keyboard layouts (like AZERTY) walterbe 2 5,640 05-05-2020, 09:54 AM
Last Post: theotherjimmy
Lightbulb A low-tech hack to help the crappy keyboard combs 11 17,823 03-04-2020, 12:36 PM
Last Post: bancha
  Pinebook 11" Keyboard Corkonian 2 4,952 11-02-2019, 07:41 AM
Last Post: Corkonian
  keyboard x0r 0 2,296 07-11-2019, 11:57 AM
Last Post: x0r
  keyboard broken? Erik 0 1,912 05-20-2019, 02:52 AM
Last Post: Erik
  Scandinavian or alternate PineBook Keyboard? GreenThing 8 11,352 04-18-2019, 02:23 AM
Last Post: freppa
Information Pinebook 14" keyboard misses keypresses UPDATE MarkHaysHarris777 22 39,055 02-13-2019, 02:34 PM
Last Post: schallee
  Swapout Pinebook keyboard? maddmike 0 1,891 12-17-2018, 02:22 PM
Last Post: maddmike
  broken keyboard -> transplant all organs into an thinkpad? stereo 1 2,827 05-19-2018, 03:25 PM
Last Post: stereo
