pi case conversions for rock64
Hello all,
I am looking for a case for rock64 board that is available in Europe. There does not seem to be any.
Has anyone managed to adapt an existing raspberry pi case for rock64 ? I would like to make a media center so it should be good looking (and cheap).
Any guides out there ?
(01-01-2018, 12:34 PM)sandradabo00 Wrote: Hello all,
Mostly you can use the Raspberry Pi case for ROCK64, just the power connector hole may need minor adjustment.
The best cases I have found are from c4labs.net. I've ordered 3 of them for various boards and I must say that they are top notch. Give it a go, you will love it!
Sent from my SM-G925W8 using Tapatalk
if you are using a raspberry pi case can you access all the connectors including sdcard, audio, lan and usb? i have understood that for the power connector you have to make the hole bigger what about the power and reset? can you unsolder and put another switches?.
(01-05-2018, 09:21 PM)MechWarrior Wrote: The best cases I have found are from c4labs.net.  I've ordered 3 of them for various boards and I must say that they are top notch.  Give it a go, you will love it!
So much shilling
I make and sales wooden case for ROCK64 in EU AMAZON.. Big Grin
I purchased a $3 case from ebay for the raspberry pi 3, made a few mods with a drill and knife. Couldn't be happier.
'Clear Case for Raspberry Pi 3 Model B Quad Core.' is the one i found on ebay.com.au
can you show us some pictures please?
Hi this is the one, but you can get it from ebay also.
I don't have pics at present, but it was easy to do, a sharp knife and a 5mm drill bit for a couple of holes. Just put the rock64 in the case and marked where i needed to put some holes or make the gaps bigger. Good luck!
https://www.amazon.com/SB-Components-Ras...B00MQLB1N6
  Are HW design files available for ROCK64? irenek 3 4,764 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 329 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,063 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 620 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,218 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,736 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,518 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,613 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,508 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,032 09-28-2021, 03:07 PM
Last Post: TRS-80
