HDR not working
Please update mpp(libmpp.so) and other vpu files needed so HDR can work in Kodi 18.
Rockchip already added it in Feb 2017, 10 months ago.
https://github.com/rockchip-linux/mpp/co...5a893a647f
Rock64 firmwares still use mpp from 2016.
(12-15-2017, 10:26 PM)Blinky Wrote: Please update mpp(libmpp.so) and other vpu files needed so HDR can work in Kodi 18.
Thanks on your discover and confirmed your finding is correct. We have inform Android engineer to update upcoming build using new mpp driver.
Please also test mpp with SPMC 17 .
It seems HDR then works in Kodi 18 but then not in SPMC 17 anymore with 'adjust display frame-rate to match video' setting set to 'start/stop'. When using older mpp, Apr-Aug instead of latest one then HDR is working in SPMC, so sometime after that a bug happened. I'm not sure if other firmware files or kernel drivers also need to be updated to work better in combination with latest mpp file.
Not sure if it is code changes needed in SPMC or mpp that need to be modified to support SPMC better also?
http://download.semperpax.com/spmc/andro...arch64.apk
  Bluetooth CSR8510 not working with Rock64 Android 7.1 efreeze 14 17,338 02-24-2019, 11:17 AM
Last Post: Poincare
  List of working apps? mcrdba 3 4,473 12-10-2017, 03:59 PM
Last Post: dudemo
  Deinterlacing not working in Kodi 17/18 Blinky 1 3,924 08-16-2017, 01:01 AM
