Confused about the Rock64 Acrylic Case
Opening the package, I see it comes with five short and long screws, along with five pins with internal threading on each side.
Clearly, the pins are meant to fit inside the holes on the lower side of the case which I assume is suppose to hold the Rock64.
My guess is the longer screws are suppose to go on the bottom side of the lower piece however, when I screw them into the pin, the long screws can only screw in half way into the pin, leaving massive excess of screw sticking out the bottom.
In addition, the pins are not at the same level when in the holes. Two are higher than other.
What is going on with this thing?
If you need any images, let me know and I will supply some.
EDIT: I think I figured it out. I recalled there is an expander for it. So therefore it seems it goes like this:
In order from bottom to top:
Long screws
Bottom of case
Rock64
Pins
Expansion board
Short screws
Top of case
Moved the thread to Rock64 section.
  Are HW design files available for ROCK64? irenek 3 4,754 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 329 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,060 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 619 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,213 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,733 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,517 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,611 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,502 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,024 09-28-2021, 03:07 PM
Last Post: TRS-80
