USB 3 2.5" SATA Case
I've just ordered my Rock64.  I have read on the armbian forums that the USB3 port can max out the Gig NIC which is great.  I was just wondering what USB 3 / 2.5 inch cases to look out for?  Is there a certain chipset I should look out for in the specs?
Thanks.
Ideally you'd want to get a USB 3.0 -> SATA using the JMS578, just like this one offered in the store
I have, however, used a few different USB 3.0 cases and (I feel I may get myself in trouble writing this) I honestly cannot see any difference in performance using a mechanical 2TB HDD. Better you read the tkaiser's post on the subject.
Thanks.
I would like to find a case that I can put my 2.5" SATA HDD in.... There are so many out there. I did see that Armbian thread about the JM578, but hoped there are other chipset that also work well under USB 3.0
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 610 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,471 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 16,420 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 15,611 07-07-2021, 05:50 AM
Last Post: Rocklobster
Heart Best quick/easy way to control case fan speed? idillicah 4 5,952 06-24-2021, 09:14 AM
Last Post: CounterPillow
  USB3 SATA ReleaseTheGeese 2 2,731 04-04-2021, 12:55 PM
Last Post: ReleaseTheGeese
  USB3 to SATA cable - Firmware Eule 0 2,182 03-03-2020, 01:31 PM
Last Post: Eule
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 2,946 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 16,003 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 5,861 06-23-2019, 08:00 AM
Last Post: rasputin
