Could you potentially create a Portable Emulation Machine with the Rock64?
I wanted to know if it was possible to develop a Rock64 Portable Console, with a controller inside of it like this:
[Image: Raspberry-Pi-Portable-by-benheck-Thingiverse.png]
Yea, I am quite certain its possible. I've built two PiGRRLs in the past and I am sure that Adafruit's powerboost1000 and control PCBs will work pretty much as you'd expect. Then there is only a question of the LCD panels/ driver boards - someone more knowledgeable would have to let us how much effort (if any) it would take a stock Pi LCD to work with the Rock64.
(12-08-2017, 11:19 AM)Luke Wrote: Yea, I am quite certain its possible. I've built two PiGRRLs in the past and I am sure that Adafruit's powerboost1000 and control PCBs will work pretty much as you'd expect. Then there is only a question of the LCD panels/ driver boards - someone more knowledgeable would have to let us how much effort (if any) it would take a stock Pi LCD to work with the Rock64.
Can't you buy a 7" inch Pine64 LCD for pretty cheap?  Huh
You were asking about the Rock64 right ? The R64 doesnt have DSI (or TP) - so the Pine64 LCD will not work. You'd need a driver board - just like you do on a RPI.
  Are HW design files available for ROCK64? irenek 3 4,685 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 316 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,036 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 608 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,160 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,708 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,471 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,572 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,409 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,953 09-28-2021, 03:07 PM
Last Post: TRS-80
