Pinebook wont turn on. Keeps blinking power light
Hey, so when I got my Pinebook, for some reason I can’t do anything with it. I have a SD card with a image and everything but when I plug it in to a AC adapter, it just blinks the power light and nothing happens. Please help
Did you leave it charging for a couple hours? Usually they are not shipped with full batteries and need to be charged first...
(12-02-2017, 02:44 AM)xalius Wrote: Did you leave it charging for a couple hours? Usually they are not shipped with full batteries and need to be charged first...
Yeah I did but it still blinks and there’s nothing on the screen
Please make sure that your microSD card loaded with Pinebook OS build, not PINE A64 OS build.
It is, I have flashed an SD card on the pine64 installer with armbian selected. Did not work, I also tried android but also did not work. Its like the pinebook turns on and off because it also makes a weird high pitched sound and it goes on and on. nothing so far is working, I even tried removing the battery and running on AC power but nothing.
Please unplug and plug in battery again and then plug in power supply, check whether this method will boot up. You can repeat this step several times until the Pinebook can boot. Once boot up, lets keep the power supply plug in until fully charge. The high pitch noise may due to the charger protection circuit keep trigger and rest.
Smile
just received my pinebook pro 64 gig   Plus a 128 Emmc chip ,disconnected the battery, replaced the emmc chip , reconnected the battery ,closed the unit , then nothing ,not even a light, dead in the wather
Did you flash the new emmc with an is? Can you still boot from SD?
I will try to reflash an  sd card to test that but like i said , no light comes on , the battery is fully charged
Flashed a brand new sd card with bionic- mate pinebookpro-0.9.14-1159
Still no lights, no reaction whatsoever
  Dead Pinebook - fix it or spare parts? oloturia 2 2,289 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 984 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,336 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 12,947 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,014 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,653 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,663 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,822 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,777 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 3,026 11-16-2020, 01:25 AM
Last Post: jay3gg
