Android Regular images are Android TV images
Hello ! I bought a Rock64 today and I am trying to install regular on it (not android tv).
I tried some images :
https://github.com/ayufan-rock64/android-7.1/releases (android-7.1-rock-64-rock64_regular-v0.3.11-r108-raw.img.gz)
http://wiki.pine64.org/index.php/ROCK64_...ndroid_7.x (Android 7.1.2 Stock Image [microSD Boot] [Rooted] [20171012])
But after booting these images are showing an Android TV display :
[Image: QyrvJZa.jpg]
Is it normal ? Thank you a lot !
Its normal. Its not 'real' leanback, just a look-alike. It has the regular playstore etc.
(11-22-2017, 11:32 AM)Luke Wrote: Its normal. Its not 'real' leanback, just a look-alike. It has the regular playstore etc.
Maybe, but the interface is Android TV like and I can't install apps like Hangout.
Is there a solution to have a normal Android on the Rock64 ?
There is an engineering version of regular android but its an early build and I do not advise using it.
Luke, how to install this http://wiki.pine64.org/index.php/ROCK64_...ndroid_7.x on RockBox?
why not install a launcher that you like? goto google play, search launcher, install what you want. it should work. but as with everything else, it depends.
I tried Nova launcher and it worked. But the top bar (notification, battery, wifi signal, etc.), buttons (back, home, overview) are not here.
And I tried to install Hangout but I can't because "it's not compatible"
this version can boot on ROCK64 4GB but it is not stable
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,219 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,009 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,534 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,178 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,000 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,479 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,983 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,566 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,702 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,758 09-09-2020, 08:44 AM
Last Post: BowerR64
