Full Disk Encryption
I intend to use the Rock64 as a multi-purpose server handling VPN, LDAP authentication, internal DNS, etc. and I'd really like to LUKS encrypt the emmc. I'm familiar with the process using Grub2 as a boot loader but U-Boot is throwing me some curves.
Has anyone undertaken a project like this?
I just use a second partition and mount bind over root where required. The advantage being the system can reboot remotely.
(11-06-2017, 04:28 AM)elatllat Wrote: I just use a second partition and mount bind over root where required. The advantage being the system can reboot remotely.
Thanks! I haven't tried that approach yet but it'd be nice to have all partitions encrypted to maintain integrity and availability.
Also, even though it's a bit of a nightmare to configure initially, initrd can be configured to load a dropbear SSH server on boot that'll drop a user to a busybox shell, allowing remote disk decryption. The advantage of this approach is that all the things are encrypted and the device can still be rebooted remotely. Like I said, it's a bit of a nightmare to configure. Maybe that'll be a future post once we figure this out.
Also, I'll admit that I have no experience with building custom Linux images and this seems like it'd be a situation where I should do just that and opt for Grub2 over U-Boot. I'm unsure of compatibility though.
@archangel @elatllat
Hi guys,
Did you manage with full disk encryption? Can you write some manual for that?
Thanks in advance.
  Encryption support rockfun 1 2,925 06-10-2020, 08:27 AM
Last Post: rockfun
  Arch Linux minimal image w/ full HDMI output support hiccupstix 1 3,639 11-01-2018, 08:33 AM
Last Post: danboid
  Problems with USB 3.0 and SATA disk (UAS) diglam 6 11,611 10-16-2018, 11:05 AM
Last Post: Trash_Can_Man
  Official Debian image doesn't recognize full SD capacity silverknight 2 3,137 08-29-2017, 06:00 AM
Last Post: silverknight
