pinebook onboard bluetooth adaptor not found at all
First off the onboard adaptor was working fine but now....
After swapping in a new emmc 64gb and loading in the latest release image of mate from here
https://github.com/ayufan-pine64/linux-build/releases
The bluetooth adaptor is not being fired up let alone found and I can't "see" it anywhere in /dev
I did put in a usb BT adaptor I have and it is discovered and connected but the onboard BT adaptor is AWOL.
Is this a kernal driver issue or other lower level issue?    I suppose there is an outside chance I buggered it when replacing the emmc.
So given that the usb BT works fine it's not BT software.
bluetoothctl does not even show the adaptor present.
Some advice please on how to track this down
If the on board bt is run through the usb bus I don't see it there.
Is this a "bug" in trying to run this latest image??
[SOLVED]
I thought maybe just the systemd service was not enabled so I did
sudo systemctl enable bluetooth
then rebooted
and yea the adaptor appeared...
so we'll call this one solved.
  Dead Pinebook - fix it or spare parts? oloturia 2 2,279 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 969 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,317 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 12,859 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,003 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,643 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,612 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,786 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,742 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 3,017 11-16-2020, 01:25 AM
Last Post: jay3gg
