Just installed Ubuntu Xenial on Pine 64+ and no sound
Hi guys,
i have just swapped my pine 64 over to ubuntu xenial and the MATE desktop enviropnment, instead of android 7 and now sound isnt working.
Sound was working with android
What is the procedure to fix this?
Once again check your sound settings.Make sure that the sound is not muted.If it is muted, un mute it and start your work.Some times it happen due to some software issues.Or it may due to failure of driver.Check whether the hardware is properly detected.Pine 64 is a single board computer and have four 64 bit cores.And you can go to the sound settings and press the test button there.Some times you may able to troubleshoot your problem.You can refer write my paper for further details regarding to this problem.
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,605 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 602 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 3,934 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 5,973 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,337 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,495 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,761 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 2,773 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,245 12-02-2019, 09:36 PM
Last Post: netHolio
  NetBSD for Pine A64(+) Luke 3 6,724 10-05-2019, 11:04 PM
Last Post: mrgtwentythree
