How to upgrade
I have installed xenial-mate-rock64-0.5.14-133-arm64.img.xz on my eMMC. I just want to upgrade to a newer release, for example 0.5.15 build-rock-64-136.
With
sudo apt-get update -y
sudo apt-get install linux-rock64 -y
I get "linux-rock64 is already the newest version (0.5.14)."
What I'm doing wrong?
Michael
you may not be doing anything wrong. build 0.5.14 may be the latest stable and the 0.5.15 build may be just a pre-release which has yet to be a final stable. i have not looked at the builds on github so i am not certain but there is usually a stable which will not update until the next final stable is released. iow, 0.5.15 might be a beta release candidate right now.
(11-02-2017, 05:18 PM)dkryder Wrote: you may not be doing anything wrong. build 0.5.14 may be the latest stable and the 0.5.15 build may be just a pre-release which has yet to be a final stable. i have not looked at the builds on github so i am not certain but there is usually  a stable which will not update until the next final stable is released. iow, 0.5.15 might be a beta release candidate right now.
0.5.14: jenkins-linux-build-rock-64-133 was a pre release, so the question is, how to upgrade to another pre release which includes some other fixes?
Have you tried
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
And what are your ppa settings ( you can see this graphocaly in software & update ) for example :
[Image: zR00S.png]
  Swap/Upgrade Storage Device? r00t3d 0 679 08-17-2022, 06:11 AM
Last Post: r00t3d
  Rock64 bricked after upgrade jean_bruder 7 7,470 04-02-2020, 09:27 AM
  how to upgrade? skipper 0 1,956 06-10-2019, 02:07 AM
Last Post: skipper
  Should I Upgrade? MotoTom 1 2,633 10-03-2018, 08:39 PM
Last Post: netadmin90
  Rock64 no longer boots after dist-upgrade KernelPanic 9 9,463 06-16-2018, 11:03 AM
Last Post: KernelPanic
  canNOT boot after a normal apt upgrade cooker 2 3,285 05-28-2018, 12:35 PM
Last Post: zaflaucich
  apt-get upgrade breaks python3 edwinbmiller 10 10,145 04-26-2018, 08:28 PM
Last Post: bony
Photo Failure to upgrade will be wrong ycllwl 1 2,261 03-26-2018, 12:53 PM
Last Post: xalius
  bionic upgrade errors 6.25 193 noob 0 2,050 03-17-2018, 01:35 PM
Last Post: noob
