ROCK64 and 16x2 LCD Screen
I am new to the ROCK64 and want to put a 16x2 LCD screen on it to display statuses.  Has anyone used one that they can send me a link to for purchase or have any hints on one that may work?
Thanks in advance!
John
Any LCD such as the following should work, they are driven by I2C bus, therefore Python I2C Library or others can be used to send display information.
http://www.ebay.ca/itm/LCD-1602-2x16-cha...3162322444
(10-24-2017, 11:35 AM)martinayotte Wrote: Any LCD such as the following should work, they are driven by I2C bus, therefore Python I2C Library or others can be used to send display information.
Thank you I will try one out...
I was thinking about something similar but with a 4*20LCD Smile
I found this link (for raspberry) but it maybe could help you? Wink
https://www.raspberrypi-spy.co.uk/2012/0...ng-python/
(10-25-2017, 12:26 AM)mikedhoore Wrote: I was thinking about something similar but with a 4*20LCD Smile
Thank you...I will take every piece of advice/hint I can!
Did you complete it? Is it working? I'm trying to do the same thing but I have little experience with GPIO.
We just got it working this morning...using the I2C pins...here is the link to the code we used... http://www.circuitbasics.com/raspberry-p...ogramming/
Hi!! I just purchased a ROCK64 and I'd like to know this little friend. Can you provide schematics or further info about what you've done? I'm aiming to get a 20x4 screen with the I2C module (from my Arduino UNO) to show IP Address, CPU Temp, etc.
Best regards from Argentina.
  Are HW design files available for ROCK64? irenek 3 4,696 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 318 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,038 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 611 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,165 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,710 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,472 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,577 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,425 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,960 09-28-2021, 03:07 PM
Last Post: TRS-80
