DietPi (ROCK64)
Community Build DietPi [ROCK64] [v156] [microSD boot]
I am digging that DietPi image and its config and software setup.
Pretty damn easy and comprehensive.
Are you going to do a ArmHF version also?
(10-25-2017, 09:27 AM)stuartiannaylor Wrote: I am digging that DietPi image and its config and software setup.
The Dietpi build contributed by DietPi community and appreciate on their work. You can explore this question at Dietpi forum.
(10-24-2017, 03:48 AM)pineadmin Wrote: Community Build DietPi [ROCK64] [v156] [microSD boot]
Awesome, get that Dietpi support on ROCK64 board.
Does anyone know about a possible emmc boot in the really near future?
I suggest you ask on dietpi forum ... they also respond to twitter PMs .
I have a 16Gb eMMC and the USB programmer adapter and I just copied the image with Win32Diskimager, popped it in and it booted right up. I have OpenVPN and transmission configured with ease. Now I just need to attach my existing 4Tb drive and find a way to get Kodi to run (waiting on native GPU support really), and I'll be a happy camper!
(02-28-2018, 10:50 PM)FlyingPoo Wrote: find a way to get Kodi to run
Hi there,
I'm waiting for my board and I'm start looking for the same solution what I have now with my RPi3: Kodi + Transmission with WebUI + MiniDLNA.
I will appreciate if if you will update with your process to get Kodi run.
Thanks.
Updated DietPi ARMv8 Stretch (ROCK64) v6.20 on Wiki and PINE64 Installer.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 137 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,332 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 325 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 599 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 598 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,270 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,619 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 584 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 637 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,000 12-07-2022, 08:22 PM
Last Post: luminosity7
