GUI is freezing for Mate on Rock64.
Hi People!
After 30 minutes (or a bit more) of system boot Mate freezes, only mouse moves but no function.
But if I enter via ssh and execute reboot it works (after reboot of course).
S.O. = MATE 1.12.1
Release 16.04.3 LTS (Xenial Xerus) 64-bit
Kernel Linux 4.4.77-rockchip-ayufan-136 aarch64
Is this a known issue?
VieiraBrazil
Yes, this isn't a blockage as such, it is the screen locking itself. To unlock it while it is like this, type in your password to unlock it.
Then you can also disable this locking feature (or bug) altogether, by going into the menu: System/Preferences/Look and feel/Screensaver, then turning off the Lock Computer setting there. You can turn off the screesaver as well if you like.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 134 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,328 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 323 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 594 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 594 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,233 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,463 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 582 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 632 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 32,938 12-07-2022, 08:22 PM
Last Post: luminosity7
