how to flash recovery
my rock64 with ayufan's android 7.1.2 atv .
I can't find any about install zip from sdcard when in recovery mode.
menu image for recovery mode  :
Android Recovery
Android/rock64_atv/rk3328_box
7.1.2/NHG47K/86
userdebug/test-keys
Use volume up/down and power.
Reboot system now
reboot to bootloader
apply update from adb
apply update from SD card
wipe data/factory reset
wipe cache partition
mount /system
view recovery logs
run graphics test
power off
is there  no "install zip from sdcard" option? who can help me ?
Happened to me. Once the recovery menu displayed, I couldn't figure out a key combination to get out of the menu or navigate within the menu. I googled Android recovery menu and found a list of key commands including volume up/down and others but there was no response from the keyboard or mouse connected to the Rock64. Unfortunately, no one had any advice so I had to reload the eMMC and start over.
Any update on the matter? How to navigate in the recovery?
I thought the buttons on the board navigate the recovery menu? i believe only one works you quick press to cycle threw the options then long press till it turns green then it selects that option
BUT, i thought you can restart threw the system in the settings? "storage&reset"
When i try it i get a rainbow spinning circle just like when you first boot for the first time so i believe this is a sort of reflash from a "recovery partition" on the storage that is compressed because after the reset it again takes a bit to start back up. ide do it that way
  Cannot flash android 9 rockchip tool totalgaara 2 4,714 09-09-2020, 07:05 AM
Last Post: BowerR64
  How do I get into Loader mode to flash an image? olivercfc 1 3,825 09-09-2020, 06:32 AM
Last Post: BowerR64
  eMMC Boots to Recovery Menu Farley56 3 5,313 09-21-2019, 02:02 AM
Last Post: elik745i
  [RESOLVED] Stuck in recovery mode Danielsan 1 2,705 04-23-2018, 09:12 AM
Last Post: Danielsan
  USB flash error elis 0 1,629 04-14-2018, 12:26 PM
Last Post: elis
  [2017-07-04] SADIE -- Simple way to flash Android to your Rock64! fire219 7 16,826 08-23-2017, 12:01 PM
Last Post: Jakr
