Got mine... can't get any IMG to boot
I've flashed and hacked so many roms and images over the years but for the life of me I can't get anything to boot....
I get Allwinner 64 Bit boot screen on one img.  The other img I used that was 7gb just boots to a command prompt.
alarm:
I type in alarm user and alarm boot and nothing. Used root/root, guest/guess. It just comes back to the next line.
I have yet to see a boot to an OS of any kind.... I really want to use these pine64 for an event coming up in June but it doesnt look good.
Not one of these will boot on my pine64 1GB:
sun50iw1p1_android_db_uart0_1000M_0112
sun50iw1p1_android_db1000_uart0_0216
sun50iw1p1_android_r18_uart0_1210
arch-pine64-bspkernel-20160308-1
android_20160112
(04-01-2016, 10:31 AM)leechyb Wrote: I've flashed and hacked so many roms and images over the years but for the life of me I can't get anything to boot....
alarm:
android_20160112
When you using Phoenixcard burn-in the Android image, please make sure that set the write mode to "startup".
alarm:
android_20160112
I am having the same problem except with one deference is i can only get Debian Linux to boot, i am also look for help with find a good image of Android for this board. i have been think the images on the website are bad. Any suggestions from anybody would be a great help. Also i Phoenixcard doesn't work very will fails 1 out 10 times, and still when it succeeds the image will not boot.
alarm:
android_20160112
I hope I will be able to help you.
You can get the newest Debian image here
Are you using windows ? if so please use windows32imager. If you are on linux then DD the image or use Disks do restore the image.
If you use Phoenix card then please make sure you got the right image: this one
Remember to set the 'startup!' mode when burning the disk.
If yo still experience problems than take a look here; Ghost did a great job putting together a list of useful threads.
Good luck!
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 40 Yesterday, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,172 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,605 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,581 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,698 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,080 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,244 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,153 10-18-2020, 01:41 PM
Last Post: toiny
  SD Card boot - trying out OS Baconomics 1 4,377 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,468 03-18-2020, 09:42 AM
