Bluetooth CSR8510 not working with Rock64 Android 7.1
I use my rock64 as a 4k media center AND as a retro console. for the latter i need a playstation 4 pad connected via bluetooth at best. I have the rock64 now for about a year and unfortunately I still have to connect my controller via a cable with the rock64 to play. Accordingly, I can not use the device for this purpose virtually. Unfortunately. because the rock is a super console with retro arch. in any case, if you could connect his pad with bluetooth.
if anyone finds a bluetooth solution for an android version i would be very happy.
(10-06-2017, 01:47 PM)efreeze Wrote: Hello Guys,
I have the Rock64 with the last version of Android installed on it. All is good excepted that my CSR8510 BT dongle is not working. I tried everything i can see on my rasperry pie with no issue but not on Rock64.
Anybody has any BT working on this platform on Android ?
Seb
I bought the bluetooth air mouse/keyboard unit sold by Pine. It works on my board with Android 7.1, except that I cannot turn the Rock64 on from the remote. After I turn on the unit manually, everything works well, including shutdown. I expected the faulty Bluetooth issue to be solved with Oreo, but looks like it got worse!
https://www.pine64.org/?product=pine64-a...h-keyboard
Seb
Is that one bluetooth tho? i had 3 different air mouse remote controls (not this one) on my hands and none of them where bluetooth, they use a proprietary transparent protocol to communicate with the usb adapter, basically from the point of view of the sbc you are pluggin a normal cabled keyboard and mouse...some backup information:
https://www.quora.com/Which-wireless-com...s-and-mice
http://www.cypress.com/file/104816/download
Apparently most of them work on the 2,4ghz frequency so interference can occur but they are not bluetooth afaik...
What can i do to somehow solve this bluetooth problem ? I have time to tweak with this and i have a willing to do that. But probably very low knowledge about how to support bluetooth device.
It is seen actually by the ATV 7.1 image (this is from dmesg output):
[ 2.146782] [1: swapper/0: 1] Bluetooth: HCI UART driver ver 2.2
[ 2.146813] [1: swapper/0: 1] Bluetooth: HCI H4 protocol initialized
[ 2.146839] [1: swapper/0: 1] Bluetooth: HCILL protocol initialized
[ 2.146865] [1: swapper/0: 1] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.146891] [1: swapper/0: 1] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.146918] [1: swapper/0: 1] rtk_btusb: Register usb char device interface for BT driver
[ 2.147188] [1: swapper/0: 1] usbcore: registered new interface driver rtk_btusb
[ 2.420490] [1: swapper/0: 1] Bluetooth: RFCOMM TTY layer initialized
[ 2.420551] [1: swapper/0: 1] Bluetooth: RFCOMM socket layer initialized
[ 2.420572] [1: swapper/0: 1] Bluetooth: RFCOMM ver 1.11
[ 2.420594] [1: swapper/0: 1] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.420613] [1: swapper/0: 1] Bluetooth: BNEP filters: protocol multicast
[ 2.420642] [1: swapper/0: 1] Bluetooth: BNEP socket layer initialized
[ 2.420664] [1: swapper/0: 1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.420691] [1: swapper/0: 1] Bluetooth: HIDP socket layer initialized
[ 2.544356] [0: khubd: 40] usb 1-1: New USB device found, idVendor=0a12, idProduct=0001
[ 2.544388] [0: khubd: 40] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.544411] [0: khubd: 40] usb 1-1: Product: CSR8510 A10 (!!!)
but no support with android settings at all. If someone could direct me, we could probably make it working. Or i'm too optimistic???
Any hope or is bluetooth dead on android for the rock64?
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,221 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,011 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,534 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,202 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,002 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,481 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,983 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,567 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,703 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,760 09-09-2020, 08:44 AM
Last Post: BowerR64
