eMMC problem
Hi,I'm now trouble in eMMC.
That is strange freespace shortage on eMMC.
I use 32GB eMMC on Rock64 xenial mate.
First,Rock64 was boot from Micro SD(xenial mate).
And used dd command to write xenial mate image to eMMC.
Write image and boot from eMMC is suceccful.
I used this command fdisk /dev/mmcblk0 and delete mmcblk0p7,create new primary pertition,rewrite this.
After that,I use apt-get update,and install any software using apt-get install ~.
but install was unsucces because freespace shortage.
I'm searching reasons, and I noticed contradiction.
that is this picture.
There are difference of partition mmcblk0p7 size in df command and fdisk command.
I thought to expand partition mmcblk0p7 was success.
But I see screen of df command, mmcblk0p7 was not expand?
https://drive.google.com/open?id=0B58MjM...lZ0U1FJc28
https://drive.google.com/open?id=0B58MjM...G5VcHhZUms
https://drive.google.com/open?id=0B58MjM...VdUdkdsMHM
I tried another eMMC card and not occuerd problem.
So I doubt initial failure.
I want to help if you know about this issue.
Thank you and sorry my bad english.
(09-24-2017, 08:24 PM)tanisou Wrote: Hi,I'm now trouble in eMMC.
I believe ayufan's latest image has already included the automatic resizing. Anyway, you can still try to resize yourself manually.  Please look at this thread: https://forum.pine64.org/showthread.php?tid=5009
Thank you to reply.
I tried latest image of xenial mate.
And my eMMC was no problem.
Thank your support.
Just got my new 64GB eMMC card in the mail and installed it. I see from previous posts that I can write the Debian image to it and boot from it instead of the SD card, That's great but I don't know the commands. Can anyone give me the code lines please?
Thanks,
Mike
Smile
(10-02-2017, 09:37 AM)mcrognale Wrote: Just got my new 64GB eMMC card in the mail and installed it. I see from previous posts that I can write the Debian image to it and boot from it instead of the SD card, That's great but I don't know the commands. Can anyone give me the code lines please?
Thanks,
Mike
Smile
https://forum.pine64.org/showthread.php?...8#pid32428
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 318 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
Question Compatible eMMC modules and benchmarks danboid 7 14,405 03-09-2023, 08:14 AM
Last Post: arvendui
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 6,082 05-04-2019, 04:19 AM
Last Post: burito111
  emmc module help default_user8 1 2,856 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Dead eMMC? machina 8 9,151 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 5,046 11-12-2018, 03:34 PM
Last Post: Tortax
  can a SD card be used as storage with emmc boot Enzo 9 12,305 05-10-2018, 08:53 PM
Last Post: pfeerick
  Flashing full image to eMMc with a mSD card to eCMM adapter pytheas 2 3,786 04-09-2018, 03:56 AM
Last Post: Luke
  Prb booting emmc darthyoh 12 13,125 03-22-2018, 07:07 PM
Last Post: pfeerick
  eMMC angelscream09 2 3,807 02-05-2018, 08:36 AM
Last Post: Luke
