ANDROID NOT BOOTING
Used etcher to flash Micro SD card with latest android from pine64 version for Rock64. Will not boot.
SD Card is good. Can flash debian jessie and it works fine. Any solutions? USING 1080P MONITOR.
Tried differenty HDMI ports on the TV.
All ports are working.
I have a 64gb emmc ordered.
Finally got an image to boot. Got the circle that said erasing for about 5 minuets. Now
just has Pinecone and ROCK64 on display. Stays there, been about 5 minutes already.
Suggestions?
What is the PSU rating ? what SD card are you using ? how did you flash the image ?
(09-01-2017, 01:55 AM)Luke Wrote: What is the PSU rating ? what SD card are you using ? how did you flash the image ?
PSU is what I purchased from Pine64 when I ordered the Rock64. 5V @ 3 amps
SD Card is new, bought from Microcenter. Works on Rock64 with Debian Jessie
Flashed it using Etcher. Also tried Pine64 installer.
The Android buuidl always takes a while to initialize on first first. Depends on the microSD card performance, the initialization time can takes around 5 minutes to 15 minutes. After first boot, this boot time will back to normal around 20-30 seconds.
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,219 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,010 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,534 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,180 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,002 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,479 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,983 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,566 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,702 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,760 09-09-2020, 08:44 AM
Last Post: BowerR64
