Mac doesn't detect USB connection with PineA64+ 1GB using LCD touchscreen
Hi, I hope someone will be able to help me. I've been trying to make it work for days.
My goal is to use the Pine64 with Android and the touchscreen to debug a game using Unity Remote.
The board is PineA64+ 1GB, the touchscreen is the one from the Pine64 store (https://www.pine64.org/?product=7-lcd-to...reen-panel), the SD card is the 32GB card from the store (https://www.pine64.org/?product=32gb-microsd), and the Android is the 6.0.1 for LCD (http://wiki.pine64.org/index.php/Pine_A6...0170209.5D).
My computer OS is macOS Sierra (10.12.6).
I've installed the Android SDK using Android Studio (version 23.0.3 of the build-tools, since I use Android 6.0.1). When I use 'adb devices' to list the devices, it is not listed. But when I go to System Information to check if it's even detected, under Hardware > USB, nothing appears. So it seems that is not that 'adb' doesn't recognize the device, but the USB connection doesn't appear to be there; the computer doesn't detect it.
USB debugging is on, I've tried changing the USB mode between MTP and PTP, I've tried different USB ports from my laptop (if I connect my phone, Android too, it works in both), I've tried different USB cables, I've tried the different USB ports in the board (using Linux the USB ports work well, so I assume is something with Android, and not the board).
Could anyone help me? Should I use Android 5.1.1? Do I need to change some configuration, or install some app?
Thank you and best regards.
  Android touchscreen capabilities? horacejlee 6 7,510 03-20-2018, 08:57 AM
Last Post: horacejlee
  Wiki version of Android 7.1 not working with touchscreen abba2566 3 5,258 02-28-2018, 08:02 AM
Last Post: wezzjm
  GeChic 1303i - Monitor / Touchscreen Totalslaughter 1 4,450 01-03-2017, 01:48 AM
Last Post: GraciaRyan0102
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,605 10-17-2016, 11:42 AM
Last Post: mathiraj
  I can get Internet Connection, However I cannot download APK File (Kitkat and Lollipo deniyulianti 0 2,236 10-15-2016, 07:28 AM
Last Post: deniyulianti
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 0 2,524 10-15-2016, 06:32 AM
Sad Airmouse doesn't work on any Android ameth 0 2,612 09-11-2016, 06:29 AM
Last Post: ameth
  How to build the lichee and Android-5.1.1 SDK@PINEA64 board. SuperX 2 4,641 07-11-2016, 09:02 PM
Last Post: SuperX
  USB Soundcard with Android Lollipop on PineA64 shawson 0 1,707 06-09-2016, 01:34 AM
Last Post: shawson
  Enable Touchscreen fsa317 1 2,969 05-20-2016, 04:54 PM
Last Post: Luke
