ROCK64 Acrylic Enclosure Assembly
Has anyone installed his ROCK64 in the 'ROCK64 ACRYLIC OPEN ENCLOSURE'?  There don't appear to be any assembly instructions....  From the product photo, it looks like the board is supposed to be pressed onto the toothed brass standoffs that are included with the enclosure hardware but the mounting holes on the board would have to be opened-up a bit in order to be pressed on to the standoffs and not damage the board.  I don't want to open up the holes if there's something I'm missing regarding the assembly...
Thanks!
Ron
(08-26-2017, 02:17 PM)ironhand Wrote: Has anyone installed his ROCK64 in the 'ROCK64 ACRYLIC OPEN ENCLOSURE'?  There don't appear to be any assembly instructions....  From the product photo, it looks like the board is supposed to be pressed onto the toothed brass standoffs that are included with the enclosure hardware but the mounting holes on the board would have to be opened-up a bit in order to be pressed on to the standoffs and not damage the board.  I don't want to open up the holes if there's something I'm missing regarding the assembly...
Thanks!
Ron
Board sits on top of the plastic standoffs built into the bottom plastic piece.
Long screw up from bottom plastic piece - toothed brass screws into that to secure the board the bottom piece of plastic.
The smaller screws are used to secure the DAC board if purchased.
If you are going to use the eMMC module, I'd recommend leaving off the top and the DAC as it's near impossible to jumper it when those are on.
Thanks @Farley56 - very much appreciated!
  Are HW design files available for ROCK64? irenek 3 4,680 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 316 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,036 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 608 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,157 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,707 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,465 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,571 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,405 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,949 09-28-2021, 03:07 PM
Last Post: TRS-80
