android 7.1 v0.3.10-r66 wifi issues
Hi ,
I have noticed the 90% of the times when I turn on the pinebook the wifi does not work. If I check the settings it seems to be active and  stuck at looking for hotspots. No amount of starting /stopping the wifi works.  The only way to fix this is to  activate Flight Mode and then deactivate it after a few seconds. Any idea? Any suggestion for a permanent fix ? Thanks
  SD2emmc custom android build Phie 0 2,590 11-06-2019, 09:14 AM
Last Post: Phie
  Privacy of Android and Chromium on new PineBook Clea 3 6,120 10-15-2019, 09:19 AM
  Android for 1080p Pinebook? Tomash 7 10,693 09-09-2019, 07:30 AM
  Android Oreo? epigon 12 20,530 07-02-2019, 03:18 PM
Last Post: TecapanV
Question 1080P Android 7? toca180 3 6,141 06-27-2019, 07:08 AM
  Stock Android for 1080P Pinebook pineadmin 1 5,541 11-24-2018, 09:45 AM
Last Post: ramboton
  Android 7.1 (Pinebook) pineadmin 50 74,797 05-30-2018, 03:13 PM
Last Post: Wizzard
  Android 6.0.1 (Pinebook) 20170605 pineadmin 6 12,627 12-30-2017, 06:55 AM
Last Post: milkaca
  Issues booting remixOS image remi 2 4,804 07-05-2017, 04:16 PM
Last Post: Luke
  Android 7.1 (Pinebook) v0.3.3-r59 pineadmin 3 7,875 05-09-2017, 04:59 AM
Last Post: Luke
