Switch found in the box
I didn't find one in my box, but I believe that you can solder that on to either the power or reset footprints by the usb ports. You can find more info in this thread: http://forum.pine64.org/showthread.php?t...wer+button
(04-03-2016, 04:11 PM)SkairkrohBule Wrote: You have assumed correctly! Smile
Time to whip out that soldering iron...
Thank you!
sorry to be a know-nothing but I'm still wet behind the ears here.
-Adam
I have just received my Pine A64 board and found that there was a little switch floating around
in the box with it (pic attached). The switch doesn't have any solder on so I don't think it's been knocked off
the board.
Does anybody know where it might go - and if I should solder it on? There are some holes
labelled "reset" that look like they might fit it?
Many thanks for any help.
The switch comes loose with every Pine64 board, because some backers wanted it and others didn't. You can solder it on the "Power" or "Reset" area found on the right side of the image here: http://wiki.pine64.org/images/7/7d/Pine6...nector.png
It's totally optional, you don't need it to use your board, but some like it as a convenience.
If I've helped you with something, please leave a rating for my responses.
(04-05-2016, 05:34 AM)pine.tree Wrote: The switch comes loose with every Pine64 board, because some backers wanted it and others didn't. You can solder it on the "Power" or "Reset" area found on the right side of the image here: http://wiki.pine64.org/images/7/7d/Pine6...nector.png
Thanks very much!
Darn, guess I have to check the bag again. Didn't find the switch in my package and used my own :-)
Cheers
Could I please get a part number for that switch? I'd like another one to solder on my Pine-board. Both power and reset accessible would be nice.
Tyia,
Captain Zalo
I didn't notice one in my box when I received it, so I just took a look on the floor around my desk where I opened the package and I found the switch under my desk. Must have fell out when I opened it. Smile
Currently playing around with Arduinos, CHIPs, Orange Pis, PineA64s, Raspberry Pis, etc.
#19
(04-03-2016, 02:10 PM)pine.adam Wrote: I received my pine the other day. 2gb version.
There was a little button floating loose in the box along with the pine board.
Did anyone else get the same thing?
If so, what should I do with it. I am assuming it is some sort of add on power button.
Thanks,
Adam
I received the same and thought it had dropped off as the board was put in the inner packing!  A little note would have been appreciated!
#20
(04-03-2016, 04:13 PM)Doom4535 Wrote: I didn't find one in my box, but I believe that you can solder that on to either the power or reset footprints by the usb ports.  You can find more info in this thread: http://forum.pine64.org/showthread.php?t...wer+button
Mine was not in the box, but the bottom of the envelope.
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,502 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Script Not Found error using PhoenixCard Ghost 4 20,695 07-16-2016, 08:01 PM
Last Post: Ghost
