Mount a HeatSink on the Rock64 using 3M Thermal Tapes
#21
Well, just got a Rock64 1GB, kind of excited when I saw the specs, but when I "make -j 3" or up armbian will generate a lot of errors (in console and dmesg), maybe because of heat. (make or make -j 2 will go through). And after I rebooted the system... bang! It was dead... Never went up again... will need to physically access the hardware...
I just want to aria2 from source...
I used kirkwood / Rpi (0, 0w, 3B), never had similar problems.
So disappointed!
Try a fresh post outlining your problem. Can you download Armbian Buster, image it to an SD card to see if your Rock64 is functioning correctly https://www.armbian.com/rock64/
Maybe it's the power supply instead of heat. Sounds a little like a classic Raspberry Pi on a marginal power supply problem.
You can try: cat /sys/devices/virtual/thermal/thermal_zone0/temp but it's weird, maybe it's not a temperature sensor. On a Raspberry Pi you look at /sys/class/thermal/thermal_zone0/temp. Divide the number by 1000 for degrees Celsius.
  Are HW design files available for ROCK64? irenek 3 4,740 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 324 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,051 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 615 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,191 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,727 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,492 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,599 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,458 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,981 09-28-2021, 03:07 PM
Last Post: TRS-80
