Keyboard commands for Android
I was wondering if anyone had good keyboard commands to perform the function of the "HOME" key in android
I know ESC works for BACK and ALT+TAB works for recent apps. But nothing seems to work for me for "HOME", surprisingly the "HOME" key on the keyboard doesn't do it.
I'm using a TV remote coupled with the FLIRC adapter and it works great for android.  Works 100% flawlessly with KODI so I may use KODI as my front-end.
(08-21-2017, 05:00 PM)Drsdroid Wrote: I was wondering if anyone had good keyboard commands to perform the function of the "HOME" key in android
http://paperlined.org/apps/android/hardw...board.html
perfect! just what i needed. Thank You!
You can also down Accesitive Touch on play store for using "home button"
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,105 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 5,908 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,477 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 166,836 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,951 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,430 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,890 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,530 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,643 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,639 09-09-2020, 08:44 AM
Last Post: BowerR64
