Rock64 has not Ethernet LAN
(08-22-2017, 03:08 PM)Luke Wrote: Newest release should solve the GbE Ethernet issue.
I just started with my rock64 with 4GB today.  Loaded ATV v2.14 r69.  Gb ethernet worked.  Loaded Kodi via Play Store, started updating large library from NAS, then the board started re-booting and lost Ethernet.  Would reboot every 5 minutes or so.  Now loaded 2.15 r77 and still no Ethernet.  Rebooting issue has stopped.  Ethernet leds blink but no IP address assigned.  Any ideas?
I also did the obligatory reboot routers, switches and even changed the cable.
Update to my last post today where LAN doesnt work.  My board does continue to reboot, but at a slower rate.  Im using version 2.15 r77.
It's look same situation with me. Don't know why and don't know how to solve this big problem. Maybe should change a new one for waranty.
Dunno maybe ATV missed the Eth mac address fix maybe post an issue on github for Ayufan.
Android 7.1 got a fix and maybe ATV missed out.
ayufan is aware of the issue, but cant solve it because his production board has been stuck in transit for weeks.
(08-24-2017, 01:18 AM)Luke Wrote: ayufan is aware of the issue, but cant solve it because his production board has been stuck in transit for weeks.
Pain I know that feeling as waiting for mine Smile
Hi Luke
After flash "android-7.1-rock-64-rock64_atv-v0.2.15-r77-update". It's still no Ethernet. The same at other firmware before. ?????????? what is that?
Hi Luke!
Please tell me how to flash this stock firmware "rock64_20170804_stock_android_7.1.2_emmc"
ayufan's 0.2.15 image includes Realtek Wifi drivers.
Instructions on how to flash the stock image are available on the wiki - for your convenience I am attaching the link.
Today I loaded this stock android image:
http://files.pine64.org/os/ROCK64/androi...mmc.img.gz
All seems to be working fine.  Im back on the GbE and no reboots (so far).  Currently updating RKMC LAN based library.  Will report back if anything major comes up.  Ive never used ATV, but the stock version of android seems very similar and comes with RKMC installed.  Working well with my Pine supplied IR remote.
If you have reboots and no ethernet, Id suggest this route.
edit: it does not.
Hello, I have the same issue with Android TV.
How we can help to resolve it?
I didn't ever build a Android image.  I wanna help.  I want to test this rock64.
I try Linux image and the X hang the board.  I need run some OS in something stable OS.
Thanks.
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,219 08-04-2021, 07:35 PM
Last Post: Rocklobster
  Android Images (ROCK64) pineadmin 73 168,173 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,999 03-12-2021, 01:38 PM
Last Post: Wizzard
  Android on Rock64 SD Problem ElBoluTony 3 5,982 10-07-2020, 12:10 PM
Last Post: ElBoluTony
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,702 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,752 09-09-2020, 08:44 AM
Last Post: BowerR64
Question Regular Android build for Rock64? fender90 18 26,172 09-09-2020, 08:04 AM
Last Post: BowerR64
  Minimum requirements for ROCK64 Android install? eugenev13 0 2,718 06-04-2020, 02:23 AM
Last Post: eugenev13
  Android 10 for Rock64? Blinky 0 3,680 04-21-2020, 12:55 AM
Last Post: Blinky
  port Rock64 to Lineage OS? noob 10 19,199 04-11-2020, 04:00 PM
Last Post: Pepe
