Serial Console for the Rock64
#31
THere is this one from Amazon, https://www.amazon.com/Adapter-Serial-Co...S486A9CQ0R  and some other  cheaper ones ones .
also.
I know this one has worked for me.
#32
The "USB to Serial" I use is the same product(probably ?) as the one below.
And it works correctly.
https://www.amazon.com/PL2303HX-Download...ics&sr=1-3
https://www.amazon.com/s?k=PL2303HX&i=el...e-asc-rank
However, products of this genre have a large number of fakes.
For example, It is often the case that the item description and the actual item are different.
Please be careful about that point.
#33
So an update- I ordered the following adapter from Sparkfun https://www.sparkfun.com/products/14050 which uses the CH340G Chip
uname output:
Linux carbon 4.13.0-46-generic #51-Ubuntu SMP Tue Jun 12 12:36:29 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
The following output is from dmesg:
[  396.785621] usb 2-1: new full-speed USB device number 5 using xhci_hcd
[  396.927062] usb 2-1: New USB device found, idVendor=1a86, idProduct=7523
[  396.927069] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  396.927073] usb 2-1: Product: USB2.0-Serial
[  396.961478] usbcore: registered new interface driver usbserial
[  396.961509] usbcore: registered new interface driver usbserial_generic
[  396.961526] usbserial: USB Serial support registered for generic
[  396.964206] usbcore: registered new interface driver ch341
[  396.964250] usbserial: USB Serial support registered for ch341-uart
[  396.964267] ch341 2-1:1.0: ch341-uart converter detected
[  396.965807] usb 2-1: ch341-uart converter now attached to ttyUSB0
I connected only the RX and GND from the serial adapter to ports 8 and 6 on the RockPro respectively (GND to 6, RX to 8)
I've tried both picocom and minicom with the following arguments:
sudo picocom /dev/ttyUSB0 -b 1500000
sudo minicom -s -D /dev/ttyUSB0 -b 1500000
And i'm getting no signal on the console when powering on the RockPro64. I also tried different combinations of TX/RX to ports 8/10 on the board to no avail.
Unsure if it could be related to my OS/SDCard as well so I have tried a few different distros using both Etcher and the Pine64 installer. So far i've tried Ubuntu Bionic Minimal (ayufan), Bionic Desktop (ayufan) and Rasbian stretch.
Any ideas of where to go from here? at this point i'm starting to wonder if I could've gotten a bad board Sad
Also it's possible that my laptop seeing the CH340G as a "CH341" is a potential issue? But not sure.
*EDIT*
I am reading in other forum posts that there should be some other white LED if the SDCard is able to boot? This is a brand new 64GB SDCard I bought from the Pine store so I don't know if that could be the issue. Also reading it's highly likely the SD Card slot on my board is dead, as apparently this is common. Any way to verify that before I go ahead and send this back for a replacement? This is starting to get very frustrating :/
#34
I too neglected to purchase the serial console with my initial order.
Very clever Pine Microsystems, Inc., now I get to order more gear.
In the meantime, could I be tweaking the linux build of my choice on the card and when I have the serial console, use an imaging software (Clonezilla for instance) to write the SD to the emmc? Sorry if it's a ridculous question.
1. Image the sd build.
2. Use that image to write to the emmc (instead of pulling an image from the network).
3. Boot into the emmc build.
4. Wipe the sd card and use it for additional storage.
I'm guessing not at all that simple but thought I'd ask.
____________________________________________________
SeatsAndChairs.com Inc.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 1 118 03-18-2024, 06:56 AM
Last Post: diederik
  Rock64 bricked shawwwn 7 5,461 03-17-2024, 12:22 PM
Last Post: dmitrymyadzelets
  Rock64 won't boot luminosity7 10 3,868 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 256 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,772 04-29-2023, 04:24 AM
Last Post: newestssd
  OpenWRT on the Rock64 CanadianBacon 12 7,799 04-24-2023, 12:40 PM
Last Post: arunkhan
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,402 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 1,975 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 703 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 907 10-07-2022, 07:50 PM
Last Post: rookie_267
