sensitive touch and android botom
I am French.... my English is bad  Big Grin
I have installed android 7 on one rock 64 2g with pine 64 to installer in sd mode
I connected a small touch-sensitive screen which works but I have 3 usual botom on android... I cannot thus use him normally. Huh
Have you a solution for this problem?
Thank you for your help
Phane
(08-13-2017, 11:58 AM)phane42 Wrote: Hello,
Phane
Hi phane42,
I am not quite sure I understand your question. Think you could post a picture ?
Big Grin
Phane
Hi phane42,
HI Luke,
it is about buttons:
Return (triangle)
(Circle) home
Make windows (in square)
I want to add them on android rock64 SD Version
Thank you Big Grin
[Image: Nexus-7-Home-Landscape.png]
Hello Luke
Return (triangle)
(Circle) home
I want to add them
Thank you
(08-15-2017, 06:41 AM)phane42 Wrote: Hello Luke
Return (triangle)
(Circle) home
I want to add them
Thank you
the version of andoid which I installed has no these buttons. I would want to have a version of android which gets closer to that of the tablet or smartphone.
Best Regards,
Return (triangle)
(Circle) home
I want to add them
Thank you
Best Regards,
Now I understand. So you'd like a standard android build. There isn't one available yet (to be precise, there is but ayufan couldn't yet make it work), but I am confident that one will be made available in the future. For now its either RK version (stock) or the community android ATV build.
Return (triangle)
(Circle) home
I want to add them
Thank you
Best Regards,
Hello Luke
Thank you,
How to use the verion " Ayufan " with a touch-sensitive screen?  Huh
Is it possible to replace the keyboard and the mouse by the only touch-sensitive screen?
Best Regards,
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,215 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,003 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,530 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,135 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,996 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,476 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,965 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,560 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,698 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,741 09-09-2020, 08:44 AM
Last Post: BowerR64
