3rd party eMMC? FM radio?
Can the pinebook work with a standard eMMC 5.0 module? The store has great prices, but there are 128gig modules from hardkernel and others: 128g eMMC
Can the FM tuner in the RTL8723CS sdio module be accessed from linux?
(08-08-2017, 08:55 AM)skot Wrote: Can the pinebook work with a standard eMMC 5.0 module? The store has great prices, but there are 128gig modules from hardkernel and others: 128g eMMC
The eMMC module you reference should work fine;  a couple of our guys have the eMMC modules for Odroid (and the adapter) and they seem to work just fine.  The store carries the Foresee modules.
( I recommend opening a separate thread to discuss the FM sdio module )
(08-08-2017, 08:55 AM)skot Wrote: Can the FM tuner in the RTL8723CS sdio module be accessed from linux?
Not seeing anything FM related in the devices in linux (would expect a v4l device for it, which my USB tuner does show)
So no out-of-the box driver support. And chances are that there is no proper antennae hooked up. WiFi and FM require quite different antennae.
(no idea on the emmc)
good catch on the existence of the fm tuner!
If anyone has information on how the FM tuner on RTL8723BS works, please post it... even under NDA, there is no real documentation of that feature Smile
I would love to try out any radio function.
it doesn't get happy
it doesn't get sad
it just runs programs
Thanks for all the info everyone! I've ordered a new eMMC.
I also tried NextRadio on android 7 sd and 6 ssd with no luck. Digging into the linux driver's source yields absolutely nothing relating to FM or VHF. I have yet to compare with the android source, but im sure its similar or identical since it works on neither. It looks like a neat wireless module, so I'm sure if more android phones start using it, we'll get further.
  eMMC compatible with Pinebook leperotero 0 1,375 07-19-2022, 07:15 AM
Last Post: leperotero
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,632 06-07-2022, 10:35 PM
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 1,516 10-16-2021, 02:03 PM
Last Post: quixote
  How to write image to emmc module on the pinebook eclay 16 33,781 06-11-2020, 03:03 PM
Last Post: jezek
  EU Shop for spare parts/eMMC? Noxmiles 4 5,671 07-05-2019, 03:16 PM
Last Post: soupbowl
  how to install emmc in just arrived pinebook dkebler 11 24,676 06-13-2019, 01:13 AM
Last Post: zk1sps
  eMMC replacement problems. frank-zappa 3 4,515 01-08-2019, 04:35 AM
Last Post: frank-zappa
  Bad eMMC? sundog 2 3,923 11-20-2018, 09:37 AM
Last Post: sundog
  Pinebook accessories (emmc usb card) RockPro64Newbie 0 2,008 09-11-2018, 07:19 PM
Last Post: RockPro64Newbie
  Bad EMMC s69arky 29 32,450 02-17-2018, 07:23 AM
Last Post: jcmartint
