Android Images (ROCK64)
#31
I'm connecting usb wifi and bluetooth to this android version and it does not work. What to do?
flashed Android 7.1.2 Stock Image [eMMC Boot] [Rooted] [20171204] on my RK3328 box but i have no root permission
how to enable it?
why first image of android 7.1 in pine64 installer does not boot?
when I use the Android Tool to flash the eMMC with the github version of Android (android-7.1-rock-64-rock64_regular-v0.3.13-r115-update.zip), it hangs on the Grey Android Logo, and never boots, even after waiting for over an hour. I don't want the TV version, I just want stock Android, is there any reason this is happening?
Hi All,
Hope you can help me.
I've downloaded Updated Android 7.1.2 Stock Image [microSD Boot] [Rooted] [20171204] and it worked.
My problem is that I need to find an Android firmware that is in "STABLE" mode and not in "DEVELOPMENT" mode.
I'm asking this to be able to run teamviewer Host or Teamviewer quicksupport on the device. I've tried it with the latest firmwares but it's crashing as soon as I connect to the device. I've written to Teamviewer support and they have aswered the following:
"I talked with our development and the problem is that we do not support the firmware which you use on the device.
The firmware is supposed to be used for debugging and tests and since it's not finished, we do not support it."
Is there a RK3328 firmware that is currently in "STABLE" or "RELEASE" stage? So I could make teamviewer run.
I don't even need the firmware to be 7.1.2, a 5.1 or other version would be fine but I can't find one.
If would be great if someone has an idea, it's now 3 weeks I try to find something :-(
Thanks!
Please label images properly I spent hours trying several different images to flash on emmc but only wasn't until I try 'mircrosd' image that it finally worked. I could have saved so much time if I knew to flash the microsd image in the first place!
Just wondering if we can expect to see an 8.0 or 8.1 release image soon? 7.1/7.x is nice, but kernel 4.4.122 includes many updates as well as March/April Android security updates. Does PINE64.ORG admin or tech folks plan on releasing 8.x anytime soon or has all development ended?
Thanks.
(01-04-2018, 09:52 AM)pineadmin Wrote: Updated Android 7.1.2 Stock Image [microSD to eMMC] [Rooted] [20171204]
Updated Android 7.1.2 Stock Image [eMMC Boot] [Rooted] [20171204]
I've flashed the above Micro-SD FW and it works well, only one BIG problem (for me, others may be fine with it), there is no Notification Bar on top and no Recents/Home/Back bar on the bottom. I'm guessing it's installed in Immersive Mode, but cannot find a way to disable it. This makes navigation very cumbersome. Confused
Any help would be deeply appreciated.
"there is no Notification Bar on top and no Recents/Home/Back bar on the bottom."
I installed Nova Launcher, try to see I can get back top notification bar back, but no luck.
I also tried other Apps from Google App Store. tweak to see notification bar, sometime, it only show half of the notification bar.
Please advise -- how to switch between classical Android 7 GUI interface with current Rock64 customized GUI ?
Really appreciated!
Beside top notification bar issue.
I also found issue with external hard drive.  I formatted an ext4 external hard, hooked up with Rock64 USB3 port.
From Android (the latest stocked image).  I cannot save any file (copy anything) to it.
I have SuperSU installed,  ES Explorer has SU permission. but still cannot copy file to external hard drive.
Really appreciated for any advise and solution.
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,246 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,016 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,541 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,012 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,495 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,998 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,574 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,719 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,767 09-09-2020, 08:44 AM
Last Post: BowerR64
  Boot Android from USB? Max_H 3 6,527 09-09-2020, 08:26 AM
Last Post: BowerR64
