eMMC ?
Just a thought but just ordered a rock64 4gb + PSU & 32GB eMMC module.
Usually I use a SD card and basically just copy the image via a card reader and hey presto.
Whilst I am waiting for delivery I am wondering how do I get the image onto the eMMC?
Never had a SBC with eMMC so a total noob question Smile
(08-07-2017, 09:58 AM)stuartiannaylor Wrote:  I am wondering how do I get the image onto the eMMC?
The easiest way is to boot to the SD card, gnu+linux image, and then use the "curl" command to copy the image directly from the network to the eMMC !
It is documented elsewhere on this forum (several times) but essentially:
1) boot SD image by using the jumper (two pins next to the recovery button)
2) stop the uboot at the timer
3) remove the jumper
4) enter  "boot" without the quotes
5) logon and use the appropriate "curl" command to download the image to the eMMC
Further to what Marcus said. There is an easy way to flash ayufan's android TV build granted you are using a Linux machine. Although fire219 said he'll work on a Windows version of his utility.
Moving discussion to Rock64 general.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,058 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 2,954 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 3,705 08-19-2021, 06:46 PM
Last Post: bcnaz
  Receiving errors about eMMC (?) acasta 11 15,804 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 28,971 07-27-2019, 04:27 PM
Brick How to Write an Image to the eMMC Module Tutorial MarkHaysHarris777 55 105,083 02-06-2019, 04:02 PM
  flash image to sd/emmc through ethernet LMM 0 2,271 02-04-2019, 07:36 AM
Last Post: LMM
  Card emmc Auggoncalves 2 3,664 06-25-2018, 03:20 AM
Last Post: Auggoncalves
  Debian to eMMC? Hoerli 7 8,524 05-06-2018, 05:41 PM
Last Post: pfeerick
  [SOLVED] stuck at emmc dr_dre 10 12,571 04-29-2018, 05:10 PM
Last Post: pfeerick
