Linux Images (ROCK64)
I installed the Debian Stretch minimal 0.7.8.
I have done the standard apt-get update, apt-get upgrade. But apt list *ntop* no longer finds ntopng. It was available in the 0.6 version. There is only ntopng-data. Is there something I have to do to get ntopng ?
(09-12-2018, 06:02 AM)Averell Wrote: Hello,
For what ever reason, only an armhf package exists, not an arm64...
https://packages.debian.org/stretch/ntopng
I've had my rock64 for a while now and been updating the builds. Noticed Ayufan hasn't updated the builds over a month but his github profile is still getting updates. Is he taking a break? Who would take over the builds if he retired?
(09-19-2018, 10:16 PM)thewonderer Wrote: I've had my rock64 for a while now and been updating the builds. Noticed Ayufan hasn't updated the builds over a month but his github profile is still getting updates.  Is he taking a break?  Who would take over the builds if he retired?
He will likely push a build this week or the next.
Thanks Luke. The active development is what drew me to the rock64 above other boards.
(09-12-2018, 06:21 AM)evilbunny Wrote: For what ever reason, only an armhf package exists, not an arm64...
Thanks for the answer.
They now offer the arm64 version.
They recommand to add : deb http://ftp.de.debian.org/debian stretch main to the /etc/apt/sources.list file. (replacing "de" by whatever suits you from the list of available mirrors.
I tried and new lists were downloaded, but ntopng is still unavailable.
They discourage installing from the .deb file :  ntopng_2.4+dfsg1-3_amd64.deb, but it is possible to use apt-get with a .deb file.
I tried, but it produced the following message :
Note : sélection de « ntopng:amd64 » au lieu de « ./ntopng_2.4+dfsg1-3_amd64.deb »
Certains paquets ne peuvent être installés.
[color=#000000] [/color]
Les paquets suivants contiennent des dépendances non satisfaites :
 ntopng:amd64 : Dépend: libc6:amd64 (>= 2.15) mais il n'est pas installable
                Dépend: libcurl3-gnutls:amd64 (>= 7.16.2) mais il n'est pas installable
                Dépend: libgcc1:amd64 (>= 1:3.4) mais il n'est pas installable
                Dépend: libgeoip1:amd64 mais il n'est pas installable
                Dépend: libhiredis0.13:amd64 (>= 0.13.1) mais il n'est pas installable
                Dépend: libjson-c3:amd64 (>= 0.11) mais il n'est pas installable
                Dépend: libluajit-5.1-2:amd64 mais il n'est pas installable
                Dépend: libmariadbclient18:amd64 (>= 5.5.36) mais il n'est pas installable
                Dépend: libndpi4:amd64 (>= 1.8) mais il n'est pas installable
                Dépend: libpcap0.8:amd64 (>= 0.9.8) mais il n'est pas installable
                Dépend: librrd8:amd64 (>= 1.3.0) mais il n'est pas installable
                Dépend: libsqlite3-0:amd64 (>= 3.5.9) mais il n'est pas installable
                Dépend: libstdc++6:amd64 (>= 5.2) mais il n'est pas installable
                Dépend: libzmq5:amd64 (>= 3.2.3+dfsg) mais il n'est pas installable
                Dépend: zlib1g:amd64 (>= 1:1.1.4) mais il n'est pas installable
                Dépend: redis-server:amd64 (>= 2.6) mais il n'est pas installable
E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l'état ».
So we will have to wait a little bit.
(09-26-2018, 05:31 AM)Averell Wrote: They now offer the arm64 version.
<snip>
amd64 images won't work on arm64 boards...
Oooops ! Sorry, confused arm and amd...
the right one is :
http://packages.ntop.org/RaspberryPI/str..._armhf.deb
I'll try and tell if it works.
Unfortunately, the result is the same, because arm64 is needed (I think) and armhf does not fit :
Using username "rock64".
ntopng:armhf : Dépend: libsqlite3-0:armhf mais il n'est pas installable
Dépend: redis-server:armhf mais il n'est pas installable
Dépend: librrd8:armhf mais il n'est pas installable
Dépend: libzmq5:armhf mais il n'est pas installable
Dépend: logrotate:armhf mais il n'est pas installable
Dépend: libcurl3:armhf mais il n'est pas installable
Dépend: libnetfilter-queue1:armhf mais il n'est pas installable
Dépend: libmariadb2:armhf mais il n'est pas installable
Dépend: libldap-2.4-2:armhf mais il n'est pas installable
Dépend: libssl1.1:armhf mais il n'est pas installable
Dépend: libpcap0.8:armhf mais il n'est pas installable
Dépend: libhiredis0.13:armhf mais il n'est pas installable
Dépend: libmariadbclient18:armhf mais il n'est pas installable
Dépend: ethtool:armhf mais il n'est pas installable
Dépend: libnetfilter-conntrack3:armhf mais il n'est pas installable
Dépend: libmaxminddb0:armhf mais il n'est pas installable
I tried to install squlite3 and some others, but the error is still the same.
Something that surprises me : is there so much difference between Ubuntu Bionic and Debian Stretch that what can be installed on the first will not on the second ? I have not been able to find the arm64 package in ubuntu packages site. They indicate it exists in Bionic, but when I click the link, there is no available download site. Why does this happen ? Two months ago, I had ntopng on my rock64 with Bionc !
Finally ! I found an arm64 installer for ntopng :
https://answers.launchpad.net/ubuntu/bio....4+dfsg1-4
Unfortunately, there are still two unsatisfied dependencies :
ntopng : Depends: libluajit-5.1-2 (>= 2.0.4+dfsg) but is not installable
Depends: libmysqlclient20 (>= 5.7.11) but is not installable
Depends: ntopng-data (= 2.4+dfsg1-4) but will not be installed
for the first one, there is libluajit-5.1-common/stable,stable,now 2.0.4+dfsg-1 all
But it does not solve the problem. And libmysqlclient is not available.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 151 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,360 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 335 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 613 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 609 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,380 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,443 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,745 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
