Rock64 europe power supply voltage
Big Grin
Hi
I wonder why
SKU: R64-PB-POWER Categories: Pinebook, ROCK64
power supply input voltage are between  110V-220V AC
In europe the common voltage is 230V AC
Is it really only 220V AC ?
I trying to look at picture in store but the picture are not so clear.
Is there any approvals like UL,  TUV or SGS ?
CE is not real approvals :-)
BR: Kaarme42
The voltage difference is nothing to be concerned about, it's just that voltage standards are often not not well defined. For example, in the US the AC voltage may be called 110V, 115V, 120V or 125V. Same thing applies in Europe.
As for testing and approvals on the power supply, I do not know. The one I got with mine has TUV and GS/SGS.
(07-11-2017, 02:22 PM)fire219 Wrote: The voltage difference is nothing to be concerned about, it's just that voltage standards are often not not well defined. For example, in the US the AC voltage may be called 110V, 115V, 120V or 125V. Same thing applies in Europe.
Thank you for answering
Many years ago voltage  220V AC was quite common in europe.
Today voltage is 230VAC and ”all quality stuff" like  good phone charge are marked 100 -240.
If yours power supply are SKU: R64-PB-POWER and marked TUV and GS/SGS it is good news.
I think they do not give approvals to europe if max voltage is really only 220V (this is only my thinking not real fact)
BR: Kaarme42
  Are HW design files available for ROCK64? irenek 3 4,738 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 324 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,051 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 615 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,183 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 4,619 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  rock64 totally brick dakobg 2 1,727 11-07-2022, 05:45 PM
Last Post: olivercfc
  Alternative power supply ju0n 0 1,011 09-06-2022, 02:46 AM
Last Post: ju0n
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,492 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,597 06-08-2022, 12:44 AM
Last Post: Zoz
